Best Bundle for $250
YoMoma
My mobo took a dive, so it`s time to upgrade a few componants. My current rig is in my sig. I want to get a new mobo/cpu/memory. I am a gamer some times, so performance is a must.
My current eguipment was bought when AMD could run rings around Intel processers. Or so they said.
I`d be open to an Intel cpu if its within my budget.
How do they compare to AMD these days?
I`ve been looking at Tigerdirect and Newegg for bundles. The best I`ve been able to come up with would be something like this....
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=4283251&Sku=MCM-M2NSLI-5400
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4222211&CatId=2417
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3981671&csid=_21
I know that these bundles are lower than my $250 range, but some bundles I have picked still need memory. I`m looking to get 4 gigs.
Anyone have any other bundle suggestions?
The P5Q Pro and E8400 bundle on this page is a really great deal. It'll end up being a bit over your budget when you factor in memory, but if you can stretch a bit, it would be significantly better than any of the ones you picked out. Note that there's also an additional $15 mail-in rebate for the motherboard, so it would come out to $240 without any RAM. There are a whole bunch of 4GB memory deals for around $30 after rebate nowadays, so add on one of those and you'd have a great combo for around $270-280.
May I ask whats better with this board than any I have posted links for?
One negative I see is no onboard graphics. Thats a downer, because my current board does not have onboard either, and if my gfx card goes bad, im up a creek without a paddle till I buy a new one.
The board itself is simply a very good Intel board. It overclocks very well, has a good amount of features, and is very stable. The CPU is the real killer of the deal, because it will also overclock very well, and it's a very fast chip. It's a lot faster than any of the AMD chips you were looking at.
