bazookaworm
- Jan 30, 2008
Hey, my friend is upgrading his computers processor to a dual core. What is the best budget processor + mobo? He probably wont use it for much other than gaming. I was thinking either buying a E2140 and ocing it(but how far can you get with just stock??) Or a 3800+ X2 or maybe even a 3600+ X2 but I don't know if those amd processors can even decently oc at all. From what i've heard the 3800 does better at stock, while the e2140 OC'd will beat either amd cpu oc'd, but at stock cooling which one is better?
Then theres the motherboard, he will only need a mobo that will allow him to OC decently and have PCIE, there are so many to choose from and by the looks of it the AMD ones are cheaper.
thanks
thanks
