Best board micro ATX, socket 939 AND nforce4?
spani
hey there,
I am searching 4 someone who can share some positive overclocking experiences with the nforce 4 or another chipset on a micro atx board (socket 939).
I've found some boards. Would be great if anyone can give me a feedback on this boards:
ASUS A8NE-FM
Foxconn CK804K8MA-KS
Gigabyte GA-K8NMF-9
ASUS A8N-VM, GeForce 6100/MCP410
Gigabyte GA-K8N51GMF-9, GeForce 6100/MCP430
Thx 4 ur help :)
biostar tforce 6100-939.
my config -
144 opteron cab2e
tt venus12 with 80mmx15mm fan (height restriction in x-qpack case)
6800gt
2x250gb maxline 3 raid0
2xpvr 150
2x512mb pqi turbo tccd
coolermaster 550 realpower
great oc options in bios not just for a matx board, but for any board. 4 dimm slots, onboard video, 2 pci slots, onboard sound. vcore options to 1.725v. vdimm to 3.1v . htt from 200mhz to 450mhz.
mine is running @ 320x9 @ 1.575v vcore, mem @ 5/6 divider 268mhz, 2-3-3-8 2.88v. temps are good considering the half assed hsf and sff case only has 1 fan, a 120mm exhaust.
asus, dfi and gigabyte are putting out 6150 boards, which have slightly better video and i/o options, but i dont see how they could overclock any better. sheck out the sff forum here.
good luck
DFI is putting out a mATX board too? Hmm...I might wait then and see what happens. I was definitely looking at the TForce.
allright. any ideas for some good RAM for the T-Force? high fsb and cheap ;)
mmmhh, i tend to take 2x512, but if they're cheap enough, i would take 2x1gb :D
depends. you will probably have to skip any vx/bh/ch/utt die ram if you are going to overclock, because you usually need around 3.2v vdimm or higher. if you want nice ram, try to find some decent tccd or tcc5. of course, this is if you want to overclock and/or spend over $140 usd. i am pretty sure you can get ocz pc3200 platinum rev 2, which are tccd for around $155 now. i dont think there have been any ram compatibility probs with this board but check out the sff forum here and check out the biostar site for recommended ram. i would stay away from the ballistix unless you are going for 2gb, it seems to be picky about the mainboards it runs on. pqi turbo, geil, ocz corsair, kingston hyper all make good tccd/5 ram. patriot, centon and adata make some good tccd also, at better prices, but are hard to find. check this list of ram. it has brand, name, revision and type of chips and pc boards. brainpower boards supposedly best.
http://xtremesystems.org/forums/showthread.php?t=50010
good luck with your new build
thx vanilla.
I decided to test my twinmos twister first. they should have some hynix d43 or hynix d5 on it.I also got a 2650mhz pretested opteron 144 with 295 FSB. Thats more than enough for me. I hope the RAMs hit 240-250 MHz, then i run them with a divider :)
thx again for the great help :)
