Best board for me?
CHollman82
I need a new board because mine died somehow, I had an MSI KT4AV and all of a sudden I started getting video glitches and games started freezing. I ruled out the video card by switching it out to my girlfriends computer and it ran fine in it for hours. I narrowed it down to the motherboard because she has the exact same one and I switched hers with mine and then it was fine. Here is my hardware:
AMD Athlon XP 2200+
1gb PC2700
ATI Radeon 9800pro 256mb
Maxtor 120gb 8mb 7200rpm
Western Digital 80gb 8mb 7200rpm
Sound Card
NIC
So, I don't need onboard anything really, though I do want the option of future expandability like SATA RAID, and Dual Channel DDR. Thanks for your help.
Although I know some have had strange problems, I have had nothing but love for my Asus A7N8x-E Deluxe
I'd get the Abit NF7-S Ver. 2 if you can find one. Either that or the AN7 which is easier to fine and has everything you're looking for. If you're on more of a budget than that, anything Nforce2 Ultra 400 should do anything you need it to to ride out the last days of Socket A :(.
Thanks for the help, Ill probably check out the Abit boards since I've had a few Abits before and liked them, like the classic KR7A-RAID
I second this board... used it for 4 months before getting my A64 system. Now it is running happily in wife's machine.
Excellent sound (NVidia soundstorm), Gigabit ethernet, SATA, Wireless upgradability, etc. PLUS flawless stability.
-Skystalker
