Best bang for bucks
maverick786us
I personally consider Corsair HX 620, TX 650 as the best PSU. But unfortunately the place where I am staying, these PSUs are on less demand therefore their prices are crazy. So can someone recommend me a juice PSU with affordable rates with which I can run this configuration?
CPU : E8400
Motherboard : ASUS P5Q Pro
GPU : HD4850
2 HDDs
1 DVD R/W
maverick786us, an EarthWatts 380 ($40 US) or Corsair VX450 would power your rig just fine. Why don't you list the psu mfg's that are available in your region, your budget, and we'll go from there.
Corsair 450VX. That system will pull around 250W under load at most, so there's no need for anything more than a reliable ~300-400W unit. The 450VX is the smallest unit Corsair makes, so it's definitely a good bet.
Antec also makes a line called Earthwatts. They're not the greatest PSUs, but they'll do the trick for budget PCs. There are 380W, 430W, and 500W models IIRC, and even the smallest one would work for that PC.
The Corsair 450VX should be enough for that build and it can be found for $70 from buy.com.
However, I recommend getting in on this deal:
Corsair 750TX 750W PSU - $98
Roughly 30% more than the 450VX but offers 45% more power. It's cheaper than either the 620HX or 620TX. And it'll give you plenty of headroom for most future upgrades.
Off course I want to over clock thats why I decided to go for this specific combination. I have chosen this rig for gaming.
CPU : E8400
GPU : HD4850
So will a 450Watt PSU be fine for such a power hungry graphic card along with 2 HDDs and a DVD writer? I thought for such a high end combination I might require at least a 620 Watt PSU. How will it perform with Corsair 520 HX? Will it be overstretched? HX520 is littlebit inexpensive here.
Unfortunately Corsair TX 750 is costing around 190US$ :(
Other good PSUs available over here are from Cooler Master. But I didn't have much review about it, so don't know how much juicy and robust they are.
Rest are all local PSU available here like INTEX, MICROTECH etc which I don't feel reliable at all :(
Let me introduce you to the page I link to whenever one of these threads comes up: http://www.hardocp.com/article.html?art=MTUzMSw5LCxoZW50aHVzaWFzdA==
As you can see, a system much beefier than the one you'll be putting together along with a 4850 draws less than 300W from the wall. Now, to find the actual draw from the power supply (since PSU ratings are for how much power they can provide themselves, not how much they can handle drawing from the wall), you multiply by the power supply's efficiency rating. The BFG ES-800 PSU used in that review generally hovers around 80-85% efficiency, so you would multiply by 0.8 and 0.85 and that would give you the range of power draw. In this case, the actual draw from the PSU is between 236W and 251W.
Obviously, that number is well within the capabilities of a 450W PSU to deliver. Not only that, but your system will use less power, since it's a dual-core, and you're most likely using two 7200RPM HDs, whereas that system was using three high-speed WD Raptor drives which most certainly draw more power than yours. Basically, a 450W PSU can handle your PC, overclocked to hell and back, and then some. Hell, you could stick in a second 4850 for Crossfire and you'd still have power to spare.
The one caveat here is it has to be a GOOD PSU which all the Corsair lines are...
the bottom line here is any of the Corsair PSUs you cant go wrong with
pick one you can get an at the price you want
the 520HX is a GREAT PSU for that set up imo
if you dont need modular then the 550VX is just as good and bit cheaper
Another thing to keep in mind is that total wattage from the wall is not the same as the load on the psu. Websites are generally going to publish the wall (ac) loads. If you're using a device (kill-a-watt, fluke, etc.) to measure the ac load then you need to factor in the efficiency of your psu to calculate the psu (dc) load.
As an example 300w measured at the wall using a Corsair 450VX would equal (300*.82) a 246W (55%) load on the psu.
You haven't mentioned your location.
But considering you speak of Intex and Microtech PSU's you seem to be located in the Indian Subcontinent.
So you can look around for the Corsair VX450, or even the POV Black Diamond 500.
The 520HX is not easily available here though.
Surprisingly, I'm going to suggest PCP&C (especially if you're considering the earthWatts 500). It's priced no higher than the earthWatts, and, unlike the earthWatts, it's single-rail (with a 35A draw ceiling on that single 12V rail), so if you're worried about peak draw, the Silencer has capacity to spare. Even better, you won't need an adapter (the two motherboard connectors are 20+4 and 4+4, so as long as the motherboard uses any sort of ATX or EPS power connectors, you're good).
PCP&C is no longer the most expensive PSU these days (typically, they are no more expensive than Antec earthWatts of the same rating), so, unless you need a modular PSU (which you shouldn't if reliability is an issue), price is no longer a reason not to consider PCP&C.
