Best AM2 build for gaming
toasterpop
Right now im running my sig system gaming but i want to switch over to the AM2 socket and im looking at the Windsor 6400+ 3.2ghz but im not sure what Mobo to go with and what RAM to get. As with the RAM near as i can find, XP 32 OS's will only recognize up to 3gb of ram, is this the same with Vista? or would i have to move to a 64bit OS?
I plan on running Sli 8800gts cards so I really want a system that can handle any game out there. Right now my system gets a bit of a challenge running Crysis with the graphics cranked up. Any help would be great.
Well first of all, what's your budget altogether for the RAM, mobo and CPU?
Second, XP can see up to 3.5GB of RAM depending on what video card you have. This limitation is inherent in ALL 32bit OSes, Vista, XP, and Linux included. If you want to be able to use 4GB+ of RAM, then switch to Vista Home Premium 64bit.
Third, what size monitor do you have?
I'll let someone else make the case for an Intel CPU.
Well if you are dead set on AMD, you're right with the 6400+ (That would be the proc I would pick if I wanted the fastest AMD gaming cpu).
How much you willing to spend for the motherboard? Do you want 2 or 4GB ram? Assuming 4...
Like the previous poster said, 32bit OS' of any kind are maxed to 3-3.5 depending on your video card. XP Pro x64 edition is a great alternative 64bit os if you don't want vista. 64bit drivers are much more abundant than they use to be.
Well depending on what resolution monitor you have, and what games you are going to play... a single faster or even a single slower card can be a better choice. Slapping two fast cards together isn't going to give you 60fps in crysis. I'm sure you knew that, but there are many many better alternatives to SLI. Plus you are going to need a heftier PSU if you were to SLI.
I have a MSI K9A2 Platinum and a Abit KN9 SLI and both will handle a 6400, my Platinum has one. The platinum is also AM2+ so if you decided to move to a Phenom later, you could. Not so the Abit
I recommend Vista 64 Ultimate
My choices were foisted on me the Abit was the only cheap solution I could find at the time (I have two SLI Boards, the other a ASUS, but I do not care for SLI, prefer Crossfire)
I am Boycotting both Intel and Nvidia right now so a AMD with AMD chipset seemed perfect for me.
Biostar 570 and 590 boards have gotten good marks
Budget: im looking to drop about $150 on 4gig of RAM, $150 for Mobo, and under $200 for the CPU. I was looking at these RAM dims http://www.newegg.com/Product/Product.aspx?Item=N82E16820227299
havent really heard anything negative about OCZ as far as Gaming RAM. Though im not sure if going with two dims is going to limit their performance vs. 4 dims of 1gb.
I dont have anything against Intel just dont really have any experience with them. Most systems ive built are budget systems with gaming farthest from mind.
other than that, i guess im looking at dropping a little on a 64bit system as well. anyone heard anything good or bad about this mobo? http://www.newegg.com/Product/Product.aspx?Item=N82E16813131011
"Second, XP can see up to 3.5GB of RAM depending on what video card you have." How does this effect the usable RAM?
I was looking at these RAM dims http://www.newegg.com/Product/Produc...82E16820227299
There is cheaper, better ram then that. OCZ makes good ram, but a lot of other makers make just as good memory. Pick what you want there, most of that ram can OC higher if you want, but it will make little to no difference.
You loose performance if you use 4 sticks of ram (as compared to 2 sticks). Not to mention it is harder to OC with 4 sticks and it draws more power.
I could suggest an intel gaming build right now (Q6600, evga 750i FTW if you want SLI), but you sound pretty dead set on AMD. But if you want a faster proc :p... ask for the intel build.
other than that, i guess im looking at dropping a little on a 64bit system as well. anyone heard anything good or bad about this mobo? http://www.newegg.com/Product/Produc...82E16813131011
Well for that price range, probably your best choice if you are still wanting SLI and AMD...
http://www.techspot.com/review/2-asus_m2n32-sli_deluxe/
http://www.neoseeker.com/Articles/Hardware/Reviews/asus_m2n32-sli_deluxe/
http://www.pcstats.com/artvnl.cfm?articleID=1974
http://www.hardwaresecrets.com/article/339
http://www.bit-tech.net/hardware/2006/07/06/asus_m2n32-sli_deluxe_wifi/1
http://www.phoronix.com/scan.php?page=article&item=506&num=1
http://enthusiast.hardocp.com/article.html?art=MTA3NCwxLCxoZW50aHVzaWFzdA==
lol Page 2 of google
Still what res are you gaming at? Would be really nice to know...
Well I believe that is a reasonable Ram choice for any Mobo. I have personally had bad luck with two of three ASUS mobo's and their RMA system is the absolute worst. I don't own and never have had a Biostar but this one seems to have good features. If you want a 590 the Biostars often require a 8-pin +12V connector that many PSU's do not have. I don't know much about the 750 Chip-set, but the 680's have been problematic.
It seems like Biostar is the big Nvidia board maker outside of ASUS.
Gigabyte has many AMD solutions. The MSI K9A2 Platinum works for me (I have a K9A2 CF board too, but for you the Platinum would be the choice.
The only Problem I have heard with your ASUS choice is the wireless, but that could just be the users and not the board.
A 6400+ is a good choice but you will need a bigger heatsink like a Sycthe Ninja
my res is at 1680x1050 on a 22in lcd but im going to upgrade adventually to either a 24 or maybe a 30 just for SnGs. Dont really know if that makes a whole lot of diff other than with the frame rate depending on the display unit.
Im not worried about cooling on really anything on my pc since everything less the NB and SB are liquide cooled, and my CPU block is AM2 compatable so no probs there.
With the RAM im not really worried about the prices, just want the best gaming RAM setup (well around $300 for 4gb is the limit i guess)
and with the 64bit OS, i messed around with a copy of XP and found that a lot of programs dont work for both 32 and 64 bit systems, is this something that will cause problems with gaming? and are the Vista 64 setups better for gaming than XP? im pretty much a novice with Vista, and right now im playing with a home premium 32 on my desktop.
I too have ran into a few problematic mobos by ASUS but i figured it was just that i was getting started on building and probably screwed them up myself. My A8N32 Sli Deluxe runs great. Only issues ive ran into were resetting the CMOS after overclocking attempts.
You would be much better off with a $150 DDR2-1066 4GB pair and investing that $150 elsewhere in your build. RAM timings make single digit percentage differences.
$150 is about my target price but if i find something thats a little more and better, i might go that route. So far, seen a set of G Skill for $85 cas lat 5-5-5-15.
Um, i dont quite understand how the cas latency works. Is lower better? such as 5-5-5-15 vs. 5-5-5-18?
could someone break that down a bit for me?
I have only tried Giel once, In my main rig now so... I recommend a look at these I think $125 end price to be pretty good.
