Phranq said:^^^
That's socket 754
what dose the winchester have over the venice for $3 more
Thats all over pal's, the fastest video card on the planet is green. Isn't the top end where these generalizations come from? Or are they excused now for having no answer?CleanSlate said:Source = ATI
Doom3 = NV
~Adam
Thats all over pal's, the fastest video card on the planet is green. Isn't the top end where these generalizations come from? Or are they excused now for having no answer? Just jumping in the stick contest. 6600GT looks like the best card in it's price range though. Source might be a hair faster on ATi's comparable card, and slower at other stuff.
Phranq said:Lug read the replies...I think you'll get our generally opinion about the 3800+...
Phranq said:No, ATI in d3d games and Nvidia in opengl that's still how it is. You can't compare the 7800gtx to last gen cards, yes the 7800gtx is the fastest, but there's nothing to compare it to. Take the x800xl and the 6800gt or something and compare. No one is doubting that the 7800gtx is the superior card on the market atm, but something tells me his budget doesn't call for one.
CleanSlate said:I agree, PCIE for new builds, X800XL over pro, definately. And I say try for dual channel 2x256 ram for $100 or one stick of 512 now and buy 512 later if you must but get at least 1gigabyte of ram and make sure you are running dual channel with it.
~Adam
Russ said:Don't get a freaking 3800+ in a $900 build.
Get this X800XL (better than pro):
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=190527
Good choice on the DVD burner. NEC is the most popular these days. If you want a DVD reader: $25
http://www.newegg.com/Product/Product.asp?Item=N82E16827131410
For your RAM I'd go with this:
Mushkin SP 1GB $90 (I personally just bought two of these.)
http://www.newegg.com/Product/Product.asp?Item=N82E16820146190
or this:
Crucial Value 1GB $106
http://www.newegg.com/Product/Product.asp?Item=N82E16820146545
Gah! That mobo is AGP! You DEFINITELY don't want AGP in a new comp. PCI-E is the way to go. The video card I pointed out to you is PCI-E. Now let's get a mobo. $89.
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=110248
I just bought one of these myself. It will be good for OCing.
Now, your proc. It is a waste of money. Get either this 3000+ Venice: $119.95
http://www.ewiz.com/detail.php?name=A64-3000BP
(I just got this too.)
or a 3200+ Venice if you can spare the money: $190
http://www.newegg.com/product/Product.asp?Item=N82E16819103535
total: $259 + $42? (I forget how much the NEC is) + $25 + $90x2=$180 + $89 + $120 = $715. I hope that fits in with your budget after you bought the rest of your stuff.
Do you need a Case, Power Supply (PSU), Keyboard, Mouse, Speakers, Monitor, or Operating System (OS)?
For PSU I'd go with the Seasonic S12-500 for $105 here:
http://www.case-mod.com/store/seaso...-500-watt-atx-power-supply-p-1579.html?src=fr
I also just bought one of these.
Phranq said:I would say nope on 64. Better driver availability on 32 bit windows.
Blah425 said:I wouldn't go Xconnect for a PSU.
Lugztaz said:honestly that dosent help cuz i don't know why you wouldn't
Lugztaz said:DONE
elite.mafia said:ummmmm I think so, but don't quote me on that, it needs to be in the right place...
You are experiencing WinXP's 48-bit LBA hard drive size limitation. Happens with all WinXP versions without at least SP1.Lugztaz said:Alright, Well i got the system setup and everything(will post pics later) installed XP Pro Done all 100+ Updates except SP2 wich was installing at the time of this post. But the 200 Gig HDD showed up as 127 Gig and when i go into Comp Management and disk management and it showed up as a 127 and another section. What to do?
