Best 27"
TexasHays
Currently I'm using a 42" 1080p plasma tv for my monitor.
Which has worked great as its pretty good for gaming and I also use my PC as a home theater.
However, long bouts of reading on it have slowly killed my interest. I will still use it for Netflix and the like but for work and gaming I want a new display.
I've checked out the forums and newegg and can't seem to decide which 27" is best. I would love 30" but those prices are out of my budget. And there's no point in moving over to a new display for the same resolution.
So I'm hoping for a 2560x1440 at least.
Any suggestions?
I am able to get a 25% discount on Apple products, so I can get the 27" Apple Cinema Display for $749 so thats the budget to beat. I'm thinking I may have to go with that as I cant find anything else with the same resolution for around the same price.
Here are your options:
Go for it if: 1. You have a compatible video card (some cards' displayport outs had trouble); 2. You are comfortable that you can get the bootcamp drivers to work, or are using a Mac; 3. you prefer a glossy screen (or are ambivalent); 4. you don't intend to use the monitor for anything other than computer use (no scaler, limited inputs).
Dell u2711
Go fot it if: 1. You prefer a matte/anti-glare screen; 2. you want maximum flexibility for inputs and scaler; 3. you are comfortable with the reasonable lag introduced by the scaler.
NEC PA271w
Go for it if: 1. You plan on doing very color sensitive work.
Dell u2711
NEC PA271w
how about the Hazro 27" as an alternative to the Apple ?
