Best 24" (Not-TN) for decent prize
avec
Are into buiyng a non TN screen. Any recommendations. Are there any good screens on the way to the market?
Some screens I have looked at.
NEC MultiSync EA241WM - not much info
BenQ FP241W - Seems good but to bright? and 2 years old.
HP 2475w - People seems not sure here
IOs there really no new good Non TN screen for decent prize?
From the other thread it looks like the NEC is a TN panel based on 160/170 degree viewing angles.
The HP LP2475W is highly recommended. The Dell 2408WFP is also pretty good now that they have reduced input lag on it by nearly half with Revision A01 and later, but I'd still rate the HP as superior.
There are also other screens (depending on where you live) from Hazro, Planar, and Doublesight which are IPS based and fairly good.
Stealing from Biges:
forums.anandtech.com/messageview.aspx?catid=31&threadid=2049206
What's your price range and intended purposes?
