best 24" lcd for gaming
combustion
trying to find one thats fast enough for games but wont break the bank, say under the $400 mark.
I am probably a pretty rare consumer. I have tried 4 different 24" monitors.
Dell 2408WFP
Samsung 245BW
Gateway FHD2400
HP W2408
IF the gateway didnt have backlight bleeding, it would be the best. Otherwise I would go for the Samsung. It can be had for $400 at samsclub or costco....
well the best reasonable on would be the planar, but thats $620. Look around old threads for opinions on other displays
If you don't want a TN, about your only option under $400 is the Soyo DYLM24D6, which is on sale pretty regularly at OfficeMax, though there's news it may be switching to a TN as well so if you want one better grab it fast.
If you want more inputs there's a Westinghouse 24" that gets down to around $400 pretty often with HDMI and component inputs. The Soyo only has VGA and DVI.
I'd suggest my L245WP pr L246WP(same thing), no input lag, no ghosting, excellent blacks, colors and no blatant blacklight bleeding. Just about the best 24" I've seen for gaming that still has excellent image quality. Also if you have a bestbuy or Circut city near you theres a chance you can get a L246WP on clearance for well under $500.
i'd rather get a smaller/better monitor than a larger/junk monitor.
$450 for a 24" isnt going to get you very much unfortunately
Check out the BenQ G2400. I highly doubt there is a better gamers LCD out there.
an HDMI cable would be a huge plus, would be nice to watch hd on it... btw is it possible to hookup a directv hd box to one? or do I need a tv tuner card?
is the westinghouse too slow for fps gaming?
http://www.bestbuy.com/site/olspage.jsp?skuId=8268475&type=product&id=1170290375980
There was talk about that monitor in depth on this forum. from the looks of it people seem to have had a decent gaming experience with it.
http://www.hardforum.com/showthread.php?t=1226712
This would be your sub-$400 choice and is a great value. It does not, however, perform as well as the Planar (in terms of color accuracy and response). But it should be great for what you need and shouldn't noticeably ghost.
No doubt the Planar has a more accurate and wider color gamut. Although, the G2400 being a TN panel with a tested 2ms input lag versus the Planar's ~12ms, I'd have to give the nod to the BenQ for slightly better hardcore gaming. Both have a ~5ms grey to grey so should have very little to no ghosting.
