BenQ GW2760HS
And Eizo has also linked PWM to flicker/eye strain, and sell some models without it, yet they are sold in the US (albeit just barely).
First of all, Eizo never made any monitors without PWM, it only made several models that don't use PWM at higher brightness levels, but do use it at lower ones, which is a big difference from what BenQ do, provided their monitors are really PWM-free (no reason to doubt that).
Second of all, as far as I know, Eizo only linked PWM to eyestrain at some obscure (to westerners at least) Japanese presentation in Japanese language (obviously), which is (again) a big difference from what BenQ do with their English language adverts that shamelessly state "if your eyes suffer, PWM-free monitor is your solution".
I'm not trying to force anyone into accepting "the lawsuit theory", perhaps it's not very likely, but by no means impossible. At least if I were in their place I would not make claims like that without some solid evidence, and no solid "PWM = eyestrain" evidence has been made public so far...
looks very promising :rolleyes:
Viewing angles on previous A-MVA monitors were rather poor to any improvement is welcome and if those diagrams don't lie this is big improvement :)
I don't know... on Eizo's website (their main one) I see this, right under monitor info:
Flicker-Free Images
Due to the way brightness is controlled on LED backlights, a small number of people perceive flicker on their screen which causes eye fatigue. The FlexScan EV series utilizes a hybrid solution to regulate brightness and make flicker unperceivable without any drawbacks like compromising color stability.
So to me, it's basically the same claim.
I assume BenQ does have some reasons behind their distribution strategy, but no idea what it is. The viewing angle improvement which XoR posted just now looks promising ... so I see no logical reason for them not to release a PWM-free + improved angle model, unless they fear it'll eat up profits on the rest of their lineup. I guess... *shrugs* unless they plan to use the rest of the world as a testing grounds, get the kinks worked out, then release a final model in N. America.
Well, Eizo says "we got rid of flicker for the benefit of a small number of people to whom it causes eye fatigue" and BenQ says "if you get eye fatigue from computer work, buy a flicker-free monitor". I do not think it's the same claim.
Got a hint from the pics posted by XoR and read up a bit on 8-domain VA. Seems like thats what they used to manufacture. S-PVA and such. Problem with those older 8-domains was the crowfeet or "half-domain" (half pixel dark at 50% intensity) subpixel layout. Beside the problems with responsiveness. We'll see if AUO has managed to get around it. There are papers out there to read but they're not free for download.
Borrowing a few shots from the mighty adtomov at avsforums.
Crowfeets:
Half-domain. Its not a perfect example but you can see that half the region goes completely dark before the other one is reduced in intensity.
251807d1310402393-lcd-matrices-differences-what-models-placed-sony-kdl-37ex521_1_s.jpg
If someone didnt get the obvious: The problem with these layout is text-clarity and various patterning in some situations.
For comparison here is previous 4-domain AMVA layout which is fine for text and patterning:
No sure about the impact is for contrast shift between 4 and 8-domain though. From browsing a few papers contrast shift and color shift are related and there ought to be an improvement there also. Also recalling people noting that older VA monitors (most probably using 8-domain layout) have less problems with contrast shift than recent AMVA.
If I were a betting person I'd bet that something have to give to improve one aspect of the panel. If its only the contrast ratio (3000:1 vs 5000:1) then it should be more than fine. But if it gets significantly slower response-timing, then it might be a bust. We'll see.
It seems that we finally have what looks like reliable information on the monitor's release date in... Japan :D
Amazon.co.jp say "this item will be released on April 27, 2013" and we should believe Amazon, shouldn't we? No international shipping, unfortunately. How I wish I had a person in Japan whom I could trust... although a person in China would be so much better!
Crowfeets:
Aside from the fantastic contrast and blacks on the GW2750HM I tested, I found the BenQ's to have several issues. Gamma shift, noticeable ghosting due to response time, and text clarity were issues for me. Since contrast and black quality is important to me I'd take these over a TN panel any day. But I am still on my mission to find a display that has better balance between pro's and con's. I decided to get off the wallet and try a Samsung S27B970D. Although I know it won't beat the BenQ's higher static contrast, a reduced static contrast might be an acceptable trade off if I can get same or near same quality blacks. I already know the Samsung will have a better response time and thus reduced ghosting and also better gamma.
older 8-domain S-PVAs had very good viewing angles and response times. Black weren't as good (worse than some IPS today) but otherwise performance was adequate. If all those C-PVA/A-MVA monitors only had contrast ratio improved and everything else was as before then IPS wouldn't be as popular as it is now :eek:
But unfortunately both Samsung and AUO insisted to make some cheap unwatchable ultra slow crappy panels instead of good ones :(
This new 8-domain panel that is used on GW2760HS brings new hope to seeing VA monitor to is up to the job of bringing LCD HDTV performance onto our desks and first good VA monitor in a very long time
if it have viewing angles and response time similar to Dell 2407WFP but with few times more contrast then it sure will be seller :)
as for text sharpness related issues: I haven't noticed anything bad with pixel structure on 2407WFP and I am ultra picky about how text looks to the point I don't even use native windows font rendering and I have good enough sight to see pixel structure from normal viewing distances :p
Well, at least there seems to be good news from Germany:
the remarkable reviewers from prad.de plan to test the GW2760HS. Yesterday, their list of reviews to come changed from "Requested the model from Benq" to "Dispatched" and I guess it won't be long now till an extensive review is available.
This certainly boosts my hope for a release in Germany (and hopefully other european countries) within the next few weeks. :)
I too would be very much interested in having a GW2760HS review on prad.de, if only to see the oscillogram.
Anyone knows how long it usually takes for them to review a monitor starting from its dispatch time?
As I witnessed the procedure in the past, the test does not take around three weeks but it takes an additional 1 to 3 months till it is available for free. If it is a matter of buying the model or not you can get the test early for 2,50 euro I suppose. Maybe I will do that for the first time as I am really interested in a display without pwm backlight.
The GW2760HS was available in Taiwan about 2 month ago. Most stores are out of stock now, even on many online shops.
Since it is hard to buy one even in Taiwan, the monitor may not be available at other counties soon. I dunno that's because it's quite popular or the bad of BenQ's supply chain.
Judging by how the number of merchants at amazon.co.jp that offer it for preorder grows every day, it's very plausible that it's going to be available in Japan pretty soon (on April 27, according to amazon.co.jp). Amazon Marketplace is not a place for con artists, unlike those fraudulent German webshops and pathetic British blogs.
As to Europe, May looks like a good candidate for a month to see its release.
First bit is very true, second and third bit comes from a cattle's behind. People are told of plans. Plans change, especially when it comes to monitors. Deal with it.
Calling something fraudulent or pathetic because you don't understand that things in this industry aren't set in stone (and that some people simply pass on what they are told with words like 'hopefully') is really your failing, not theirs. I'm not trying to flair up hostility again here, but I find your misplaced negativity a bit tiresome to say the least.
I really don't believe that I should elaborate on that, since anyone who read this thread and is capable of reasoning will surely understand why I'm justified to use these expressions, but I'll still state that "fraudulent German webshops" refers to those putting the products they don't have for sale while not marking them as preorder and "pathetic British blogs" refers to those publishing false information and when it exposed as such making up pathetic exuses like "BenQ don’t seem sure what exactly is going on" (very good for a laugh) or "you can buy stock imported from places like Germany where these models are available" (a blatant lie).
And contemptible exuses invoke nothing but contempt, which any exuse-maker would do well to remember, be it an attention-whoring blogger or a forum poster suspiciously interested in his defense.
You're right, the information is there and people are entitled to their own opinion.
Let's have a look at exactly what that blog you're talking about said. I have their feeds aggregated and saved, so I know this:
Latest word from BenQ is that they are aiming for a late February release in the UK with no word yet on availability outside of Europe.
As I've said earlier in the thread I quizzed them about this in early March. That is genuinely what they were told by BenQ and their PR firm and were simply reporting that. They were aiming to have the whole GW60 series out in the UK in late February. You can interpret that as you like, but I think you have completely over-reacted and are frankly being a bit of a drama queen. There is a reason nobody else is fuming away at that website. They accept that they were just reporting what they were told - never did they say that the monitor WILL be released then and there is really no need to get annoyed at them. :confused:
In all fairness, what you said is not at all relevant to me. But since you just won't stop getting to me, I'll ask on what basis you have ruled out the certainty, I mean possibility, that they were lying? Even if you consider them above suspicion for some weird reason you can't expect everyone else to share your conviction. Their "you can buy stock imported from places like Germany where these models (BenQ GW2760HS including, my note) are available" statement means that some of them are either at home with lying or as "naive" as Forrest Gump. What is a greater possibility?
And I think you behave like a drunk who tries to provoke a lamp post into a fight.
If so, there has to be a reason why nobody else is defending it, isn't that right, genius? So then what's your reason, monetary or otherwise?
Firstly, the reason nobody else is defending it is because they have no issue with it. People here are sick of telling you to cool it or would rather keep out of it and I don't blame them, this whole one-man crusade of yours is pointless. Secondly, I have no reason to believe that they are lying, that is a poor rationale you are using to excuse the fact you have completely misread what they have said. They are a trustworthy source and spend a lot of time and effort finding out things, testing and reporting about them in an open and honest fashion. Unlike you who just sits here trying to stir up s**t and only occasional posts something constructive.
Secondly they were responding to a comment there where somebody said "I found one seller on amazon selling the 2760HM for $306". I am fairly sure they are talking about where to get the HM model(s) from. You could always post a comment yourself and I'm sure they would clarify. Or I can do that for you.
You just admitted that you do have an issue with it. Care to tell what's your issue?
How about I tell you to cool it and stop your "one-man crusade" of defending the long lost honor of that blog? Will you listen?
You can believe what you want and nobody's gonna give a damn, just stop trying to force your semi-religious beliefs or lack thereof on me or anyone else. If that blog is your deity, I have no problem with it as long as you allow me not to share you religion.
I'm not sure such shameless advertising is allowed here. And in my opinion anyone who considers them trustworthy ought to have his head examined. The moment they're caught lying, which obviously happened, they're no longer trustworthy.
That's plain hilarious, a pot calling a kettle black. In case you haven't noticed, it's you who for some reason keeps getting to me "trying to stir up s**t" and not the other way around. And when was the last time you posted something constructive, in your previous life?
Well, guess what? You can take your excuses and shove them. It's pretty obvious that by "these models" they meant GW2760HM and GW2760HS, so your wordplay is completely irrelevant.
I meant others are being passive, a wise move on forums to stop things like this happening. And there have been no lies, you simply misinterpreted what was said. Added a level of certainty that was never implied. When that was pointed out you then started calling them liars. But this has gone far enough, I'm sure we both agree.
So some questions. Does anybody here actually own this monitor (imported or otherwise)? I want to know if the ColorShift Free thing is a feature you can turn on and off or something thst is always on.
The monitor is available in Japan, it's official.
Several Amazon.co.jp Marketplace merchants indicate to have it in stock, and, as I already stated, Amazon Marketplace is no place for con artists, meaning that any merchant lying about an item's availability risks bad feedback and/or a case against him, so no comparison with individual webshops that can claim what they want to rob a customer of what he has with total impunity (although in practice this is mainly done by Germans).
Any jetsetters who wanna take a quick trip to Japan?
Well I placed an order from cumputeruniverse.net they have them in stock and the total was $337.27
http://www.computeruniverse.net/en/products/90502015/benq-gw2760hs.asp
I will let you know once I get it. :cool:
My congrats to German scammers, they claimed another victim. "They have them in stock" :D, please give me a break.
Would you mind telling what it says in your order status (My Account > Order Management, look at the "Status" column of the "Current orders" table)?
Hopefully good news, everyone: Benq support just answered my request for the displays availability in Germany. The translation:
"Hello Mr. Awesomeville (name changed),
thank you for your interest.
The display will finally be available in calendar week 22 at our distributors (api, Ingram Micro, Tech Data).
Best regards
Andre Geier
BenQ Europe
http://benq.de"
Calendar week 22 ranges from 27.5.2013 to 2.6. - so the release date 31.5. that some distributors gave me seems about legit. Hopefully.
Oh well. Another whole _month_ and B-2 is banned. I see the connection. Too bad I never saw that last post. Must have an been epic fit of rage. :)
Some stores around my european parts have showed it to be in stock next week for a couple of weeks now. I guess thats a ruse. They'll probably all use the same distributor.
The "May/June boundary" release date looks very probable indeed given the circumstances, I noticed that some other models appeared in Europe about a month after the Japanese release, which in case of GW2760HS was on April 26.
Regarding computeruniverse, as ratta41 could tell you nearly a week ago (I'm kind of not surprised he wouldn't) they blew their April 29 "expected receipt" date just as they blew three dates before that. It now says "Receipt of goods expected on 16.05.2013 (current non-binding details from our suppliers)" in my order status. Ironically, the sentece almost contains the truth, I mean if you remove "supp" from the last word and substitute "e" with "a" you'll get the most probable state of affairs. Just as I predicted, the current date is exactly 17 days after the previous one. It seems that Germans are so lacking in the imagination department that they can't even randomize the dates they invent. On the product page, however, it now says "An estimated dispatch date cannot be given", which probably means they decided they cheated enough people into ordering.
I couldn't tell you that info before, since I was on a mod-sponsored vacation. No hard feelings on my part as I have clearly overstepped my mark, especially when I called Firepc a genius. I mean, it's practically as bad as calling Einstein a retard would be.
Don't jump to conclusions, you saw as much as you could and there was no connection. BTW no post disappears from this forum without a trace, I'd say a year should be enough for you to notice that.
well dont they speak english in japan? maybe theyll do some reviews
Playwares haven't published their review of the GW2760HS, but in their AOC 2963 review they included a lot of test results of the GW2760HS.
Pretty promising, at least not any dealbreakers:
Contrast ratio: 5085
Black level: 0.06
Max luminance: 352
sRGB coverage: 102%
NTSC coverage: 72%
Default gamma: 6870
Response times:
GTG, AMA Premium: 5.4ms
GTG. AMA High: 8.6ms
Input lag: 8.6 ms
http://www.playwares.com/xe/index.php?mid=maingame&category=19628503&document_srl=30024613
Just abandon all hope of getting this monitor any time soon...
Thank you for that piece of information, it indeed sounds promising especially in combination with a flicker free backlight.
