Why wouldn't you go with RAID? Storage is cheep and if/when your hard drive goes bad and you loose all of your "videos" because you don't back them up. That would be a bad day.
What hard drives do you have price out in your build?
RAID IS NOT BACKUP
I've lost count the number of times my raid 1 has failed, and it doesn't fail nicely. before it actually fails you can degraded performance. its degraded to the point where the computer is unusable and you might as well just pull one hard drive off and hope that is the good one.
what I do now instead is just install the two hard drives separately and have a script that backs up my data to the other drive.
Hmmm, so should i even go with raid at all?
what about for an HTPC that will store numerous movie files?
You either do what I do, or backup to an external drive.
But you have to ask yourself do you REALLY care about those movies files? I don't care if I lose everything as I can just re-download everything.
Though I agree with you - if you're looking for backup a scheduled sync makes a lot more sense - your RAID setup is clearly broken if you have that kind of trouble. This isn't representative of a properly configured RAID.
I was using NV raid 1 and regular consumer drives which were not designed for raid, but then if you think about it defeats the "inexpensive" part of RAID. So you tell me, what is "properly configured"?
I think ill just stick with a regular old harddrive setup
OP: A periodic sync has some real advantages over a RAID1 setup in your situation. It's also easier and less failure prone to set up. Just schedule a task to run robocopy or rsync between your disks every night and you're done.
