Zangmonkey
- Jul 6, 2005
I am going to build an i3 system in a silverstone GD06:
http://www.silverstonetek.com/product.php?pid=293&area
They note that the vertical limit of the heatsink UNDER the optical drive is 70mm
and then the usable height in the case in 120mm
I'm trying to think of how I can cool it most quietly.
If I use the prolimitech genesis:
http://www.prolimatech.com/en/products/detail.asp?id=801&subid=804#showtab
the horizontal side should fit nicely under the optical drive, while the vertical part extends behind it and can rise up.
The problem is that the genesis is 160mm tall but if I were to bend its vertical tower to a 45 degree angle then it would fit.
I still need to see if the 110 mm or so of additional horizontal space is available but I'm just weighing my options with bending the heat pipes....
I could also cut off the top 40mm of fins and bend the heatpipes down....
