Behringer vs M-Audio
FrEaKy
[H] Movie and TV Show Review Guy
Im looking at the M-AUDIO AV 30 2.0 speakers for $94.99
As well as the BEHRINGER B2030P speakers for $104.30.
Which is better in your personal opinions?
*edit: I am leaning towards the B2030P's right now! And no, I am no longer looking at Swans!
the 2030p are much better but they are passive and will require amplification
youll need an amplifier for those B2030P's so youll have to buy an amp for them and those things dont come cheap i suggest you get speakers with amps built into them already like the AV40's and the 30's. what are you going to use them for anyways?
true but an amp would set him back 100-150 more quids and i dont think the OP knows that the 2030p needs an amp, but if he has one already or is planning on getting one then kudos to the OP
Yes, already have an amp! :) but thank you for making sure at the same time!
Yeah I saw alot of reviews that put the 2030P up higher than most speakers, but I dont trust alot of review sites much anymore cause it seems more and more they are in it just for the free stuff....... (not hardocp of course!). SO I wanted a regular opinion from people who purchase the products! :)
I've always said you don't buy Behringer products, you rent them from the trash can.
That said, cheap knock off gear has it's place. For example my 8ch mixing console is Behringer. Why? Because I needed it cheap, and quality was not my utmost concern.
my DEQ2496 would disagree. ;) dunno bout the speakers though..
I had one, it was a neat piece of gear, but iffy on quality. There are a lot of mods out there to make it sound better... replacing most of the output section.
It was ok for live stuff and recorded ok, but I wouldn't use one in the signal chain of playback material.
Dont have $250 to throw around!......
I am not using these for recording or critical listening, just general usage!
Are you going to be doing recording/critical listening, or are they for general use? I highly recommend saving up for the Maudio BX5A's. They're about $244. I've been using there older sibling, the BX8A for years now.
http://www.amazon.com/M-Audio-Studiophile-Bi-amplified-Reference-Monitors/dp/B0014IEBM0
the BX8a is the bigger version of the Bx5a but they both sound identical just that the Bx8's have more of a lower end
get this instead
http://www.amazon.com/gp/product/B001T9O5UM/ref=ord_cart_shr?ie=UTF8&m=A1729W3053T57N
Alesis M1 520 u wont regret it man
its $18X.XX in the shopping cart dont get fooled by the $400 price tag
also this competes witht the Bx5a but youll save $70 more so its a steal
The Behringers are technically near field monitors although they claim a much larger "sweet spot" though they don't quantify it. If you're going to be listening to these mainly at a desk at ear level then I'd say go for the Behringers. If not, you may want to look into some unpowered book shelf speakers since you already have an amp.
Thank you friend ;) I think Im gonna get the Behringer's.
