Before I hit submit on this expensive system...
mcravenufo
Ravenufo's Macs
Does it look? I would hate to spend this much and have something I missed be incompatible.
I HAVE:
K8N Neo4 Platinum/SLI
Antec PlusView1000AMG
Thermalright SLK-948-U
Lots of fans
BUYING:
PC Power & Cooling Turbo-Cool 510 Express / SLI
2x BFG Tech Geforce 6800GT 256MB GDDR3 PCI-Express x16 Video Card - Retail
AMD Athlon 64 3700+ San Diego Integrated into Chip FSB Socket 939 Processor Model
CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered TWINX1024-3200C2PT
Western Digital Caviar SE WD2000JD 200GB 7200 RPM Serial ATA150 Hard Drive
Western Digital Raptor WD740GD 73GB 10,000 RPM Serial ATA150 Hard Drive
Plextor PX-716SA 4X Internal Serial ATA Dual Layer DVD±R/RW CD-R/RW Drive
Logitech Z-5500 505 Watts 5.1 Speaker - Retail
Ugh, SLI...
You should just buy one 6800GT (or Ultra, if you wish), then upgrade when the GeForce 7800 series is released only a few months from now. SLI is a big waste of money.
I'd also switch out the WD 200 GB hard drive for a Hitachi T7K250. The performance is a bit better, and the drive will be somewhat quieter as well. At $119 for the 250 GB model, it's also cheaper per GB. If your heart is set on WD, that's okay too.
I feel left out with everyone recommending hd's so I will 1up them all!
Dont get a raptor at all, get the WD3200, 320gb drive which is one of the quietest, coolest, and a pretty darn fast drive to boot.
Quietest? Many Samsung drive owners would disagree with that assertion.
xonik said:
Ugh, SLI...
I know, I know...SLI. I did do some searching here before I got into it. The small improvements may not be worth the money but I wanted to try it anyway. Since there is something always around the corner, I will sell the cards and get a GeForce 7800 when they come out.
i wouldnt get the sata version of that plextor drive, ive read in other forums that they are having problems. i got the ide version. ive been told not sure if its true there is no difference between the sata version and the ide version other the sata version uses sata cable. been told they both perform the same. :cool:
Having the Serial ATA cable is convenient. No worries about jumpers, big IDE cables, and skinned knuckles (from pulling out the power plug!). And Plextor is a reliable brand, to boot.
Yeah, they will preform the same. I got the SATA for cable neatness. I have heard problems with the drive being incompatible with certain motherboards but I am hoping a firmware update and some luck will help IF I have problems.
The Raptor is for the OS and Game Installs. I will probably make 2 partitions.
The 200GB is mainly for file storage.
Well, you're right about that, but the cost/GB figure may be of interest to you anyways.
