BC2 max out with 6950 @ 1920x1200?
dakrat
hello, I am thinking of upgrading to a 6950 and would like to know if this card can max out the BC2 with a 1920x1200 resolution? what FPS are you getting? I would like to know before I dump the cash. no CPU bottleneck here. thanks!
It doesn't' sound like it will. What are you running? I have a 4850 512MB and I play at 1080 w/2xAA. Game only get sluggish when there is a lot to be rendered, but that is b/c i am limited on VRAM:p
I am running 6850 overclocked to 900/1200 at 1650x1050 on high in BC2 with MLAA and GPU usage is at 80%. FPS is 50s to 60's, but I only have a Core 2 Duo E8400 at 3.7Ghz and it's pegged out at 100% on both cores and definitely holding my GPU back in this game.
easily :p Check out the hardocp review. I run my 6970 @ 2560x1600 2xaa everything else to full, HBAO off.
I can really help you with this one. I have the HD5870 and I am running BC2 at 1920x1200 with everything maxed out (including 8XAA 16XAF HBAO ON) at 50-70 FPS. This is really the reason why I did not opt to upgrade anything on my system yet. That 6950 is faster than my GPU so definitely it will run even greater than mine.
Yes, you will be able to max out BBC2 at 1920x1200 on an HD6950. However, you will be looking at a frame rate of around 45 minimum and 50-60 average with 4xAA and HBAO enabled, I suspect. If you want a minimum of 60fps you may have to disable one of AA or HBAO.
I too am running a 5870 and with everything maxed (8x AA, 16x AF, HBAO on) Im getting 45-85. I would say a 6950 should be ok at 1920x1200 cause its only slightly slower than my beloved 5870.
Anandtech benchmarks of BC2
Drivers cause a comparative performance drop in BBC2 that doesn't occur in other games causing HD6 series to underperform their known HD5 counterparts. Thus, an HD5870 will outperform an HD6950 to a small extent, whereas normally the reverse would be true.
There are several things you can do to get better performance from your ATI cards in BF. Turning HBAO off is one of such things. I was using a 6970 at 2560x1440 and found it to be subpar so I swapped it down to 1920x1200. After messing with a few things in the ini file I run it at 2560x1440 without issue.
Does anyone even notice a difference with HBAO? I have it on, but only because I can.
I definitely notice a performance hit with HBAO on. I didnt notice a drop in graphics quality because I went up in resolution when I turned it off.
You'll easily be able to max out BC2 with a single 6950 at 19x12. I'm running CFX 6950s with 3x23" screens and I can max everything out.
Just be prepared for some serious dips. In heavy MP action you can get easily below 30 FPS even if your avg is 60 FPS. Maybe its driver issue, maybe game issue. But its true.
Depends on the rest of your rig, but I'd say definately. My 6970 has no troubles at eyefinity resolutions, so 1/3rd the res it should kick ass.
That is really heavily dependent on the CPU. Stuff starts blowing up and your CPU gets hammered hard.
Well, I actually never noticed that. I mean, I have been running on the battlefield with windowed game, CPU usage opened, nd never noticed any near 100% load.
It will run, but not like butter. I'd say spend $50-100 more and future proof yourself anyways.... you're just going to be half-assing it next year with that card and in the same boat again. So unless you are SUPER TIGHT on cash, save another bill and get something that will surely MAX OUT and also last you a lot longer for a better "bang for your buck"
Spend $50-100 on what dude? The GTX570 and the HD6970 are the only things available for just $100 more, and the performance difference between them and a 6950 isn't so big that one or the other will "future proof" him. Besides, he can flash the 6950 and get a nice boost in performance.
Or, he could CFX two 6850OC. But yes, it has other disadvatages. But performance-wise can beat GTX 580. But you need CFX enabled MB, with at least x8 x8 PCI-E lines.
not really, x4 and x4 will do it too. There's almost no difference between 4x and 16x on PCIe 2.0, at least not yet. Two HD6850s will easily surpass a GTX580 in anything that supports crossfire.
6950 (not flashed). Everything high, HBAO off, 4xAA give me ~50 avg and 40 min.. I'd say you'll be good. I think it plays amazing!
I think I will wait for the next generation of cards to come out. my oldie GTX280 gets better performance than that. same settings HBAO off and 8CSAA :eek:.
That depends on the resolution. Generally speaking, what the GTX280 can do at 1280x1024, the HD6950 can do at 1920x1080.
What CPU do you have? There was a difference for me jumping from a Q9650 to a 980X.
I know people say a single GPU can handle 1920x1200 well. But I've notice games are much smoother for me in crossfire. If Bad Company 2 is all you play an additional 6950 might help. I heard very good things about 69xx multigpu scaling.
Everything max HBAO and Bloom on with 16xAF and 4xEQ ED AA (12xEQ); upper 80's avg with dips into the mid 60's.
I'm not recording any graphs to back that up, but I have MSI Afterburner displaying GPU stats on my G13 lcd and I check it fairly regularly, especially during real heavy splosion action.
HBAO is real subtle, but i love what it adds to the game.
It basically darkens the corners where things meet. Like rocks laying on the ground, corners of walls, etc.. Just about everywhere something touches something else.
To me it adds alot to the realism. Without it, things look like they're floating just above whatever they're resting on, and just makes the lighting more realistic.
Well, I read different. x4 x4 is bottleneck for two 5850CF, so it would be for 2 6850CF.
I'm running 2500k @ 3.3ghz
4gig 1600 corsair vengeance ram
6870 at 950/stock mem
Everything maxed out even AA and I get 50-60 fps 1920x1200
HBAO and vsync on as well
