Ahh yes. Let's release a DLC Expansion before the main game is even fixed. Nothing like hurting the bug/balancing process by introducing more content.
Maybe the guy got out before the tank blew up?
Domination, Conquest, Conquest Large. No specific map. I get about 4-5 populated servers. Some with only a few players.![]()
They are investigating it per Twitter feed from Battlelog. It sounds like it is in error or started early.
Since the patch and new performance drivers not getting any crashes and performance is through the roof. Me likey.
Scored almost 60k points in one round last night doing AA at the dam level. Was really fun, I think I moved up 3 levels in that game.
I am just waiting for the AA nerf. Pretty powerful stuff as it is. You have to stay away from tanks and C4-ing infantry, but I love the 30mm with rockets. I dont use the radar and HS missiles much if at all, plus as pilots get better, they will be able to avoid them, so I figure ballistic is the way to go.
I noticed what I thought was negative progression the other day as well, but so hard to tell. When I rank up, it flashes across the screen like 3 times over the curse of 30-40 seconds. Just in case I didnt see it the other 2 times I guess?
getting 100% XP boost tonight without actually having an XP boost applied. unannounced double XP event?
Anyone know if this is still the case???
I use the built in one since msi afterburner doesnt support 64bit yet.
Not surprising, because its EZMODE now in BF4 compared to how it was in BF3, especially on that map since enemy armor can't really get to it due to chokepoints.I think its the only vehicle in the game you can play with one hand while eating lunch. Absurd.
I tend to avoid that map since its usually a guy in MAA pussycamping in safety of his base just spamming active radar missiles all round which hit RU heli's as theyre taking off. Cheap.
What's the command?
I didnt buy this game at day-one launch cause I knew it would be unstable.
I just bought it yesterday and installed it on a fresh copy of windows7 with 331.82 WHQL nvidia drivers.
I am getting horrible pauses/skipping that is making it unplayable. I did the core unpark fix but it changed nothing. I dont know what to do next...
Its smooth the first 3 minutes of gameplay then it starts pausing, it doesn't matter the settings. It will go from 60+fps to 0.
Any tips?
Okay, couple things. That article says its for win8 or 8.1Did you let Windows install network drivers? If you did, I would suggest installing drivers from Asus or network card company. You may have a memory leak.
http://www.reddit.com/r/battlefield...dows_8_bf4_memory_leak_the_cause_and_the_fix/
