You may want to include the resolution you intend to play at.![]()
1920x1080
or something a bit less than that...
1920x1080
/looks over at Saitek Cyborg Evo
Dedicated (or non-dedicated, depending on how you look at it) server info posted: http://forums.electronicarts.co.uk/battlefield-3-pc/1419188-first-look-bf3-pc-game-servers.html
where'd you get non-dedicated from?
They better have bf2-ish controls for planes/choppers or i'll be uber pissed off. I absolutely hate the dumbed down version, I want there to be skill in flying.
Does anyone know how the 60mm mortar will work?
I heard engineers will be able to deploy them.
Alright , from what I understand vehicles regen armor over time without the aid of repairing? Seriously? someone please tell me this isn't true. Another issue is the spotting system which takes bush wookie camping to a whole new level
http://www.youtube.com/watch?v=7e_cLfMjsQk
What is the purpose of a ghillie suit when you can just prone and remain perfectly hidden.?
People who didn't play the alpha should be banned from complaining about features they don't understand.
The vehicle regen was slow as shit and not gamebreaking by any means. You still needed engineers and a competent driver to keep your vehicle alive.
90% of the time someone just charged in with it and died had it disabled or destroyed within 10 seconds. get fixed, immediately panic and floor it into the nearest tree, get stuck, blow up.
fucking retarded.
fucking retarded.
it's NOT like oh fuck vehicles at 2% better back up 10 feet and be fully repaired within 5 seconds. you only regen (slowly) from minor damage and if you take too much, your vehicle is disabled.
you can still fire while disabled but you can't move and you bleed health, need an engineer to help.
Then please enlignten me as I would like to know the following
Can you see across the map as a sniper in BC3? (ie BC2) BF2 was never like this and kept camp happy snipers from pitching a tent due to the distance fog that was used in the old engine. Banned from complaining give me a fucking break ?Regen has no place in vehicles period! slow or not. I've seen more absurd complaints in games such as GUI layouts (UT3) and mouse movements which can be addressed via ini.
I have a Q6600 + 4GB RAM + GTX460x2 (SLI, and yeah, I'm severely CPU bottlenecked), but I plan on getting a new motherboard, i7-2600k, 8-16GB RAM, and an SSD.
Will that be enough for pretty much maxed settings at 1920x1080, or should I also look into getting a GTX580 or something?
For what reasons? other then the obviousThe fog of war was one of the worst parts about BF2.
Can you see across the map as a sniper in BF3?
That sounds far less intolerable than the traditional regen-health.
If your CPU is clocked over 3ghz (3.2 - 3.4 range) you are not severely bottlenecked. 460x2 should be great for 1080p at near max settings (you may not be able to max AA/AF and whatnot). I would definitely go CPU upgrade before GPU.
I recall a quote from a DICE employee stating that if you can run BC2 well on high, you should have little problems with BF3. I will try and find that quote and return.
also that spotting doesn't exist any more, it's purely 2d spotting for infantry.
I thought they said it was still 3D spotting but you had to have line of sight for it to show? Pretty sure that's what DICE said, but maybe they changed their minds again.
So, a soldier in direct Line of Sight that is spotted will have a 3d red marker. If he moves behind cover or concealment, including vegetation, the 3d red marker will disappear. He will always be on the minimap. Vehicles are always fully 3D spotted, and LOS does not apply since they are larger more important targets with less threats (and it plain did not work to have jets flying around who couldn't see the tank you spotted for him to take out).
This lets you essentially "nudge" your buddy to tell him about a target, or point out a sniper on a hill you see but cannot engage (with your shotgun for example). But it prevents players from using 3D spotting as a wall hack.
Additionally, the primary motivator for the change is that 3D spots that you cannot see are not threats. We noticed that players would focus on 3D spots over everything else, meaning they would ignore people in line of sight. It's far less confusing when the 3D spot on a soldier can only be seen if you can see the soldier.
So then what's the point of it?
Apparently so the vehicle can be disabled but retain small amount of health so it can still fire its weapons.
I believe once a vehicle is disabled, the health regen will not make it driveable again though an engineer can repair it back from that. Once a vehicle is destroyed though, there's no repping the wreck back to useable.
Vehicles get disabled with a few hits and the regen turns into a bleed. Only regen if slightly damaged.
Source: http://twitter.com/#!/Demize99/status/104437993036722177
fucking retarded.
