Battlefield 3 General Discussion Thread
Hey guys i'm from Peru. I'm planning to buy Battlefield 3 for PC ( for the multiplayer). Oh and in about two weeks i'm buying a new videocard, a Radeon HD7950 Sapphire OC edition. Will i be able to play multiplayer at least at high settings with these card ? Thanks:).
Btw, where can i buy BF3 at a good price ?
Regards
if you're playing at 1600x900 as shown in your sig then i imagine you'll be able to play on Ultra with a decent overclock on the 7950. as far as good prices go, both Origin and Amazon have sales on BF3 pretty regularly.
Regards
provided you game on the resolution in your sig, then yes. also upgrade to 8gigs of ram if you have some spare cash. really helps and ddr3 is dirt cheap now.
edit: if you want it cheap and don't need a box you might want to look into buying just the cd key. they go for around 25 to 35 bucks, new.
I got mine 3 weeks after launch for about $20 from one of those CD key sites. Not an issue to be had. It's the Russian version, but the english patch files always get posted a day after patches come out (which is pretty far inbetween ...).
8 gigz isnt even enough for near ultra settings, I was hiccuping, had to get 16 gigz.
8GB was perfectly fine for 1920x1200 for me with everything on maxed except motion blur off (hate it) and 2x AA.. It wasn't even bad for 5760x1200, but the ~35 FPS wasn't smooth enough for me and I kept having to drop settings until I decided to go back to 1920x1200. My 8 to 16GB upgrade did nothing for my BF3 experience.
Wish I could join faster. Was thinking a jump from 8 to 16 would help.. Must be the SSD's that are beating me to the punch.
I wish DICE would make a benchmark for this game for stability testing.
This game rapes your system more then any other proggy I ever seen.
I guess you have never heard of Prime95 or IntelBurnTest then. This game isn't that crazy, Prime95 got my CPU to get up to 70C with a lower ambient temperature than now, BF3 gets it to maybe 63C when I've been running my PC all day and my ambient is like 30C.
Intradesting considering I never drop below 45FPS with everything on Ultra and 6gb of memory...hurrrrr
You can still hiccup even @ 100 fps.....
OCCT>Prime 95 :D
In any case im mainly talking about GPU stability testing.
Same. There are lots of russian key sites, and many are bullshit selling used keys or keys that will be used.
I got mine through 1C, a Russian publisher responsible for many great games. I purchased from them as they are a legit, verified company, got a legit key, patched to english and have been playing since release. Fully compatible with US expansions etc. I think I paid $21
So did they fix the DART glitch? I just unlocked it a few minutes ago just to see how "op" it is and I was only getting 2-3 hit kills and from short-medium range. Hell, I snuck behind a guy but was fairly far away, aimed down the sights, hit him and it showed it hit but he didn't die, then shot and hit again but didn't kill him at which point he turned around and shot me dead.
The M26 dart as a standalone doesn't glitch, you have to attach it via underbarrel to an assault rifle.
It only attaches to certain rifles, you select underslung attachment for the main weapon, and m26 will be attached to the gun.
you want the g3a3 with underslung and m26 and I think heavy barrel.
I went from 4gb ddr3 1600 to 12gb and it was a massive difference. I had a problem where when I zoomed in with my sniper rifle, the fps would drop to like 2 for a split second and I would also get random stuttering. That is completely gone now and the game runs very smooth. It seems odd that this game requires sooo much memory. The ps3 and xbox have what 512 mb of total memory?
and 1/25th of the draw distance and graphical quality. Everything past your gun is blurred to shit on the console cause it can't draw it in any detail.
Not sure why people are saying they need 16/32 gb of ram for this game. I'm using these settings with my hardware without a hitch on 6 gb ram.
Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 @ 4.4 Ghz |Gigabyte GA-X58A-UD7 LGA 1366 Intel X58
Corsair Dominator 6GB DDR3 1600 (PC3 12800)|EVGA 015-P3-1482-AR GeForce GTX 480
Intel X25-M Mainstream SSD 80Gb|Seagate Barracuda 7200.11 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s
Corsair HX Series CMPSU-850HX 850W|ThermalTake Kandalf
Prolimatech Megahalems Rev.B|2x CoolerMasterR4-L2R-20AC-GP
HP 2509b 1920x1080|Logitech Z-5500 505 Watts 5.1 Digital|MSWin 7 Ultimate OEM 64 Bit
[/IMG]
you should crop that thing down!
I will try and remember to track my ram usage next time I play
when i had 8gb of ram, and played for an hour. fresh off a reboot
but I am running 6970/6950OC xfire and eyefinity.
yes
then go troll TDM and get bitched at
I feel dumb, how do you attach it?
It only works withe the M26 DART.
It needs the underbarrel attachment, but some weapons don't have it physically attached to the gun, which is what is required - they just allow you to select the underbarrel but still switch to the standalone MASS.
M26 DART + underslung rail (G3 works) and heavy barrel.
Do you have an SSD?
2 in RAID. It's great. I really wish I would have made the move long ago honestly. Even with my elderly X58 setup I'm completely satisfied with the performance until the next round of serious games hits.
I remember when I played BF1942 with 256 MB of RAM, map changes would take about 60 seconds but when I upgraded to 512 MB of RAM map changes took less than 30 seconds. I love how BF3 takes about 5-10 seconds to load a map. Yes I have an SSD.
EDIT: I should mention I just upgraded from 6GB triple channel to 12GB and the map changes are about the same.
The Crucial M4's are the most often recommended. I also like the Intel 510's. The Intel 520's are newer, faster, and cheaper. Apparently some are hesitant to recommend them due to the new unproven controller the 520's use. I'm going to get one as soon as it drops to about a $1 a gig. You should take this search over to the Data Storage Section before this BF3 thread gets derailed with SSD discussions.
Good luck.
Do you have an SSD?
I dont have an SSD and load maps in seconds.....
These maps load faster then BF2 maps......
Good luck.
If I were to go SSD I would only look at revodrives, nothing comes close.
I originally had BF3 on my SSD and maps loaded in seconds.
I stopped playing as much and needed the space so I put it on the WD Black 2TB.
How bad could it be?
Pretty bad.
I only play 2-3 games at a time so I'm going to add a second SSD just for the current games...
Pretty bad.
yeah I really need to get another SSD
