- Sep 2, 2004
First some things to mention about this the combo. The SOFLAM is very difficult to pick out, as it is an extremely small device, unless it is facing you. The other method is if you know some typical spots the spot can sometimes pick out (this is unreliable). The javelin users, nor does the recon deploying the SOFLAM, need to anywhere near the SOFLAM or each other, this means they can spread out extremely far apart. Javelin users are not really practically distinguishable, so specifically targeting them is basically a non starter.
SOFLAM's currently can be placed in areas that are extremely difficult, or sometimes not accessible at all by infantry. Javelin's combined with SOFLAM's can lock without line of sight, meaning completely behind cover. Even if you have a stacked team and control the map, you can still have people encamped with SOFLAM's and Javelin's in the deployments, which can range and cover quite a bit of the active combat areas depending on the map. Also as mentioned they do not need to be next to each other, so you cannot just clear them out.
Air units versus it is slightly more complex to illustrate. First against the chopper, the Javelin will 1 hit kill it and not miss, nor can be countered via flares, it is also attacks downwards meaning you'd need an extremely elite pilot and favorable circumstances to block the shot via the terrain. So what are the choppers options? If the SOFLAM does get picked out, TV missile or somehow sneaking up on it can take it out. But keep in mind the recon is free to instantly redeploy, possibly at a completely new location, losing nothing from that exchange.
Against jets you have the same spotting issue. If is picked out then a jet can reasonably take the SOFLAM out. But there is also the danger if placement is next to AA emplacements, also ground attacks make you extremely easy targets against opposing jets. The redeployment issue also again crops up here. Taking out a SOFLAM basically again is basically no real loss.
Some good points. I would say that against land vehicles I'm cool with the Javelin + SOFLAM system as-is, but against aircraft it's really pretty retarded. I don't actually think the real Javelin can be or is used against aircraft, anyway. That's what a Stinger is for.
