overlord20
- Feb 5, 2010
Have a budget of $400-500.. The Less the better
. I was thinking i3-530 and mATX with 2gb ram and then a cheap pci-e 2.0 gpu. Probably 500gb hdd. If its possible awesome! if not thanks anyway
.. This is to replace a pentium 3 for my uncle. forgot to add PSU. Thanks
EDIT:
Sorry...
This is a basic use pc. Browsing the net, watching vids, word proccessing.
$400-$500 or as cheap as possible. Tax including shipping not.
3) Where do you live?
USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU- i3 530?
GPU- Something cheap
PSU-
Mobo- mATX
case- cheapo something
HDD- 500gb
none
6) Will you be overclocking?
no
Standard 19" (non wide)
Next Few weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing special.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes
EDIT:
Sorry...
USA
CPU- i3 530?
PSU-
Mobo- mATX
HDD- 500gb
none
no
Next Few weeks
Nothing special.
Yes
