Basic Server
tgray96
Basic Server Duties
250 Tax/Shipping Not Included
3) Where do you live?
Indiana
Mobo,CPU,HDD,Ram
N/A
6) Will you be overclocking?
Only If Its Worth it
N/A
Immeadiately
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
N/A
Win server 2K8 R2 64 BIT
This is what i have in mind
SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152245
BIOSTAR A780L3L AM3 AMD 760G Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138290
G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231307
AMD Athlon II X2 250 Regor 3.0GHz Socket AM3 65W Dual-Core Desktop Processor ADX250OCGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103903
The Ram Would be doubled at a later date
i am not worried with the other parts at this moment: PSU and case
Well we still need to know that info. What's the point of recommending parts if you're just gonna pair it with a shitty case and/or PSU?
All righty then. Do note that PSU is currently $40, $25 lower than the standard $65. That's a sales price and it's not gonna stay in stock for long. So I highly highly recommend getting that PSU ASAP if you don't already have it.
I'd spend the extra $1 for DDR3 1333 RAM for better RAM compatibility in the future:
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
Besides that, your build looks good to me.
awesome thanks! i'll switch that ram out and when i get my paycheck next tuesday, i'll order everything (-the case) Thanks!
if not, i'll have to put the psu off for 2 weeks, which means i'll get the case and psu at the same time.
