- Feb 6, 2013
This may be a stupid question but I bought these fittings for my new build
http://www.performance-pcs.com/barr...d-rigid-tubing-compression-fitting-white.html
The fittings came with 2 identical o-rings. Is one just a spare or do these fittings use 2 to compress the rigid tube on to the fitting. My rigid revolvers only came with and required one o-ring to compress the tube. TIA
