Barbs or Compression Fittings?
Which do you use?
  • Barbs
    Votes: 9 42.9%
  • Compression Fittings
    Votes: 12 57.1%
  • Total voters
    21
Mr. Baz
I already read the FAQ, but I want to know what everyone is using.
Pros/cons?
almost went compression but everything comes with barbs so i just went with it
lol was just checking back on this and its 7-7 so you still dont have your answer then?
Depends on the need for "looks" vs the budget. I use whatever meets the need at hand and tend to use compression fittings on blocks and barbs on the rad because I change blocks more often than rads and usually the rad fittings are out of sight. But just depends. Compression fittings everywhere can get expensive. So I did not answer. Done properly either type of fitting works fine.
