Intended use is 50% gaming, 50% fairly undemanding web production.That's why I'm sticking with dual core for now. Sometime in the new year, depending on perormance reports and prices, I might add a second 4870X2, get Vista, a new PSU, and a Cosmos case, and also another 4GB of RAM if the DIMMs will fit.
I'm pretty excited to get this system going as I am definitely CPU bound right now in newer games.
New parts are in italics:
XP32 (for now)
Cooler Master Wavemaster*
Enermax Libery 500W**
ASUS P5Q Deluxe
Core2Duo E8600
2x2GB OCZ PC2 8500 DDR2 1066
160GB WD Raptor 10K
500GB Seagate Barracuda 7.11
Sapphire Radeon HD4870X2
Creative X-fi platinum
Zalman CNPS9500AT cpu cooler***
NEC DVD multi-burner
LG Blu-ray multi-drive
Logitech diNovo RF edition (fuck bluetooth)
Logitech G7
Dell 3007
Logitech Z5500
* Wavemaster has notoriously bad airflow, but I modded mine to have a few extra cold air intakes and great cable management, so temps are competitive with newer cases.
** Many smart-asses will tell me the Liberty PSU is woefully underpowered for this system at "only" 500W, but I beg to differ. I'm already using this PSU with the 4870X2 in my current box. X24400+ and Core2 take about the same power draw. A 4870X2 takes less power than the X1950XTXCF in Crossfire with the X1900XTX. Finally DDR2 takes less power than DDR. So I should be fine until I add any more parts.
*** Parts being replaced include ASUS A8R-MVP, X2 4400+ on stock cooling, 4X1GB OCZ PC3200 DDR 6400
XP32 (for now)
ASUS P5Q Deluxe
Core2Duo E8600
160GB WD Raptor 10K
Logitech G7
Dell 3007
Logitech Z5500
