Bah this is lame...
markt435
So i got the new mobo (in sig) and was finally able to overclock. Highest stable I can get is only 2546 no matter how much juice I put into it. Judging from the OC database, there is only one version of the e6300 that could be pushed way past its limits huh? I don't know the details on mine. I just know it aint gonna go further than 2546 lol. Lame.
I have a feeling its not the cpu, but probably either the motherboard or memory that are holding you back.
Well I'll have to wait as it is the 650i. I haven't found a bios update for it yet either. The board seems to have just come out even though the Platinum version has been out for a few months. Hopefully a bios update will fix it if that is the case.
As for the RAM, it is overclocked as well. I've been doing them seperately and found a base speed that was stable to start with. Its currently at 844. Maybe I'll focus on that for this weekend.
Not that I am aware of, lots of date codes there and that database is fairly old, updates are rare past December with the 4300 information being the newest. With stock HS complete newcomers normally make 2.8 with no or modest increases in Vcore and only stop because of temps. That seems a decent board but its too new for me know any tricks.
Perhaps if you gave us your voltages, temps, memory timings and cpu and memory speed settings FSB etc. someone who knows that Nforce chipset could cure your lameness.
ok i'll write everything down and post it brb lol
EDIT: Ok
These are current figures from the BIOS as CPU-Z doesnt work right for me...
CPU Speed - 2559
FSB - 1455
RAM - 839
Vcore - 1.44 (its been lower before...I just left it higher when i was trying diff speeds)
Mem - 2.05
NB - 1.25 (default)
SB - 1.50 (default)
RAM Timings:
tCL - 5
tRCD - 6
tRP - 5
tRAS - 20
Everything else is Auto.
Chipset is nForce 650i SLI w/ 570i Southbridge...Yeah kinda weird but it seems to work well for the Platinum version. Gotta love the frankenboards.
The NB is craving more voltage at that fsb im thinking, give it a few more .1v's and see if it helps. Try keeping the memory at its stock speed or close to it to rule that out also, using the dividers.
No luck. I took the NB to 1.4 and was able to get 1550 but it wasn't stable enough to POST. Anything under that would boot to windows but then freeze. So I'm back to 1455 which is rock solid stable. I even took the mem down to 667 and it still no worky. Any idea besides the NB? Could it be the BIOS and should I wait for an update before trying again?
Lock the PCIe bus at 101?
PCI bus at 33 (not always needed... don't think you do this on the 650i).
ok will try again... will edit here
EDIT: Ok I got it up to 2625, stable for 30 min under OCCT. I actually used both the above suggestions. Seems above that though...not really stable.
EDIT2: This shit is weird. When i read another thread on the Mobo board i tried 430 fsb. Didn't work. So then I brought it down to 425...working stable so far. Everything in between 1500 to 1700 is unstable. /me scratches head
Used 1.4 vcore and 1.45 NB
