assassin's creed 2
splinter cell conviction
prince of persia the forgotten sands
starcraft 2
Ungine heaven 2.1
3d mark vantage
the stuttering appear only when the frame rate drop under 60 fps.
up
all ati radeons are same ?
http://forums.extremeoverclocking.com/showthread.php?t=347342&page=2Problem solved ... I think i was having two different issues. The RMA and a bios flashed fixed the card but the pauses / lockups were due to a failing Sata port. I was seeing 100's of atapi ide contoller errros in the event viewer. I changed sata ports and problem is gone. It's been 3 days now with no issues and no atapi errors in eventviewer. I guess whenever the game was trying to load data off the hdd it wouldn't do it fast enough and caused the game to lag. Thanks for everyones help.
SSD will not help with in-game stuttering, unless you are having issues with texture loads from the hard drive (not likely).
i think he ran out of memory and is using the hdd.
i bet he got so many processes running and programs that he doesnt know about. im sure the system has eaten up 2gigs of memory, so that leaves him with just 2 gigs for games.
he should dl the new GameBooster software, i think that would help him.
