Bad Motherboard?
mikesroth
Hi All,
Well I attempted to setup the wife's new computer last night, and had something new happen to me, and could some advice on where to look for the problem.
She got:
Thermaltake Dream Case
Enermax EG465 Power Supply
MSI K8N Nforce4 Ultra Motherboard
AMD 64 (939) 3000+ Cpu
MSI 6600GT PCI Video Card
Seagate 80gb Sata Hard drive
Stole her CD Roms, Floppy, and 3200 Memory from her old machine.
We got it all together, with some very sloppy wiring, I wanted to see if it would boot up. (that is my excuse and I am sticking with it).
Anyways, the machine came one, I hooked up the monitor to see what it would say, mentinoed that I needed to go into the Bios to adjust something. So like an Idiot, I turned it off, so that I could place it closer to her keyboard, mouse etc... and attempted to turn it back on. Now it won't come back on at all. On the old Motherboard there was a light on it that would come on when you had the 'power' hooked up. I don't think the MSI has one, but maybe I am wrong? If the power supply was happy, but the mobo or cpu was shot, would the fans come on? they don't either.
Anyways, I could use any suggestions to trouble shoot this, as I need to get her OFF my computer. :) and I still need to setup my new setup,and don't want to make the same mistake twice (if I did something).
Thanks for any help and advice!!!!
Michael
Maybe the PSU went bad? If you have another one sitting around I'd swap it out and try it. I'm only thinking this because you said the fans don't turn on. Yes, normally there is a light on the board also when it's running (I have the neo4 SLI, so I'm assuming it is the same). Did you double check the connections? Is the ATX/12V connectors on tight? If all that doesn't help, you might have a short in your case. Take it out and try it on some cardboard to see if it boots up.
I am hoping that it is just a short, well that and that is somethign fixable. :) I do have another Power Supply, the wife's 'Computer Rules' are that we have to have the same of everything. She is a bit competitive, so I do have an extra power supply of the same kind. My only worry is that I did something to hers, don't want to kill mine also. :D
I plan on unconnecting everything, and reconnecting to see if somethinh wasn't in all the way, and then taking out the Mobo to see if that helps also.
One last thing, there seemed to be a connection that I had no idea what it was for. It seemed to have only 1 endpoint, unlike the 24pin and company, and it seemed to come from that 'bundle'. Is this normal? If so, what should I be connecting it to?
Thanks!
Michael
So let's isolate the power supply from everything else. If we can at least get it to turn on, that's a plus, right?
To test the power supply, you can do this: Unplug the power connector from the motherboard. Connect the green and black wires on the power connector with a paper clip or a piece of wire. If the power supply fan kicks in, the power supply is probably good and your problem is likely the motherboard. If the fan on the power supply remains still, you may just have a dead power supply.
Here's a pick of what your jumpered power supply connector should look like: http://www.webhelp.org/jonnyguru/atx/paperclip3.jpg
Jonny,
Should I unplug the Power Supply from EVERYTHING else before attempting this? I want to make sure that it does not need to be connected to something else.
Thanks,
Michael
I would disconnect it from everything. I also don't know what you're describing above with that extra connector.
I went to the Enermax site, and it looks like it goes into an adapter that came with the power supply. The EPS to ATX GES adaptor or the EPS to ATX 12v Adaptor. I am assuming that I dont need any of these.
Thanks for all the help and advice by the way!!!
Michael
mikesroth said:
Jonny,
Thanks,
Michael
Absolutely. Troubleshoot the PS alone. You can also try to start up the machine if the PS is working and tap the "DEL" key every one second until BIOS loads up, and then see if you can try to boot-up from a disc. You'll have to change your settings in BIOS.
It sounds to me from what you've said before, that the PS is likely the problem.
Good luck :)
Thanks!
Michael
Good idea. Re-trace all of your wires to make sure thaey are connected. Also make sure you are grounded before you "go in".
Ok, one question on this. I never have been able to get a straight answer from anyone. It seems like the 'Hardware Guys' here are work don't every ground themselves before working on machines, so they are never any help. :)
We have those wrist grounding cables that you can attach to something to ground yourself. I really don't know what I should be attaching myself to though. I have heard the case is fine, but, what is grounding the case if my power supply is not attached to its cable? Last night we had slightin unscrewed the screw on a wall outlet and attached the cable to the screw (had heard that was a good grounding source). The problem with that, not much room to move. Any suggestions?
Thanks!
Michael
You can lay some anti-static sheets of plastic that hardware gets shipped in, on a table and lay your machine on top of that. Make sure you are not standing on carpet and just keep one hand on the frame of the machine when you stick your hands in. This is what I do and works fine keeping static away when I'm working inside a machine.
As for the cable attached to the wall, I've never tried it but if you want to keep it that way just get a longer cable and run it to where you keep your machine. Hope this helps.
Thanks!
Michael
If you've got a spare PC power cord, take the part that plugs into the wall and cut off the blades, leaving the ground pin. Use that to ground the chassis.
Ok, here is where I am at now.
Unplugged all the cords, removed the video card, replug the power cable: Nothing.
Remove the motherboard and place it on the static pad, and plug it to the power supply: Nothing.
Since I had another powersupply, I replace it with the new one, and hooked the motherboard back up. CPU Fan and PSU fan are working. So I turn them off power supply. Then turn it back on, dead again.
I have another Mobo and CPU that I can try, but I am afraid that I might be doing something bad to them.
Any ideas or suggestions?
Michael
Did you connect the green and black wires on the power connector with a paper clip or a piece of wire?
See, you're getting it to fire up once and then not again. But let's say you DON'T swap out the PSU, but instead unplug it from the board, unplug it from the wall and then plug it back in. Is it still dead or does it fire up the first time like it did before.
Also: ANYTHING installed in that board? You don't need or want anything plugged into that board for starters. No CPU, RAM, video card. We're not trying to get a post so that stuff doesn't matter. You're just trying to get it to turn on!
Also, make sure nothing is plugged into the power supply other than the board. No drives, etc.
No, forgot to get one from work. I was hoping replacing the Power Supply with the other one we bought might suffice... Looked good until I got the bright idea to turn it off, and turn it back on.
So then try unplugging it from the motherboard and then unplugging it from the wall and then plugging it back in again and seeing if it does the same thing.
If it does, your two power supplies are fine. Something is tripping a protection circuit in both of them.
OK... I think I found something. WHen I 'RESET' the CMOS I can turn it back on (forgot) I did that when I switched the PSUs. Then when I turn it off, dead again. But good again when I reset.
Take the CPU out and try it.
Have just the motherboard and the PSU. No CPU, RAM, etc.
Do it again.... Does it do the same thing? Do you have to clear the CMOS to get it to power up again?
If so, bad board.
WOO HOO.. Figured it out. Good thing I've been reading all the pages. :) A friend from work was talking with me about it and something I had read about memory voltages rang a bell. I found the article and turned it off from AUTO and put it to 2.5 (We have corsair 3200), and it is all happy now.
THank you all for the help and suggestions, I was getting kinda panicky as this is the first 'within' seeing distance of latest technology computer I have ever built. lol
Michael
