bad ethernet port or isp?
kingdomwinds
Recently, I have been getting disconnected briefly from the internet. After a few minutes, i can reconnect. I checked the ethernet port on my motherboard and the lights were blinking when the disconnect happened. But how do i tell if this is just my isp acting quirky or my motherboard's ethernet port gone bad?
easiest way I can think of is by a process of elimination. Disable your onboard NIC and use a pci NIC. If your drops go away, then it's probably your mobo NIC. I had to do this with an old DFI NF2 mobo that I had. I was too lazy to go through the RMA process.
use the Ping command from the DOS box and repeatedly ping yourself using the Loopback 127.0.0.1 use the -t parameter to let it run as long as you like then use ctrl-C to stop. You should have a very low ping time and no lost packets.
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\Administrator>ping loopback
Pinging adrie [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Documents and Settings\Administrator>ping /h
Bad option /h.
Usage: ping [-t] [-a] [-n count] [-l size] [-f] [-i TTL] [-v TOS]
[-r count] [-s count] [[-j host-list] | [-k host-list]]
[-w timeout] [-R] [-S srcaddr] [-4] [-6] target_name
Options:
-t Ping the specified host until stopped.
To see statistics and continue - type Control-Break;
To stop - type Control-C.
-a Resolve addresses to hostnames.
-n count Number of echo requests to send.
-l size Send buffer size.
-f Set Don't Fragment flag in packet (IPv4-only).
-i TTL Time To Live.
-v TOS Type Of Service (IPv4-only).
-r count Record route for count hops (IPv4-only).
-s count Timestamp for count hops (IPv4-only).
-j host-list Loose source route along host-list (IPv4-only).
-k host-list Strict source route along host-list (IPv4-only).
-w timeout Timeout in milliseconds to wait for each reply.
-R Trace round-trip path (IPv6-only).
-S srcaddr Source address to use (IPv6-only).
-4 Force using IPv4.
-6 Force using IPv6.
C:\Documents and Settings\Administrator>ping -t loopback
Packets: Sent = 25, Received = 25, Lost = 0 (0% loss),
Control-C
^C
even better is to do it from another machine if available with the target being the machine in question.
I had same problem with my DFI Lanparty NF2 Ultra-B mobo.. It got fixed inadvertently when I used hacked BIOS(for OC'n) and different drivers. Not a problem since. but did have to use a PCI NIC until I found out the onboard was fixed.
Probally your ISP then but I hesitate to make any concrete conclusions based on one test.
If it gives you enough time next time it goes down, try to ping yourself for a few packets and then real quick try to ping your ISP
like ping verizon.net
If you can ping yourself but not anyone out on the net, then probally for sure it is your isp (or your router/modem).
