Bad caps or bad power supply or something else?
BBCMember
A client of mine went away for a week and his computer was off. Then, when he came back and attempted to boot up, it powered up for about 2 seconds, and then shut off immediately after that. Then he tried booting up again right after, and it wouldn't do anything...no power, no nothing. So he waited a few minutes, tried it again, and it did the same thing as before...powered up for a couple of seconds and then nothing.
So, he tried the following that people have suggested to do with this specific system (which is a Dell Precision 470 running XP Pro SP3, 3.40GHz cpu, 4 GB of RAM, 250GB HD) when having this issue:
1. Unplugged on usb devices
2. Cleaned out tower of dust with air can
3. Changed the CMOS battery (changed it within 2 or 3 seconds) - BTW, nothing was reset jumper-wise when he changed the battery...could that have anything to do with this issue? Do we need to reset the bios or load default settings?
None of the above helped. So he ordered a new PSU, which I have just finished installing. Now it powers up (but the PSU is noiser than the original one), but is hanging at the Windows bootup screen (where the blue dots under the word "Windows" are going back and forth).
I looked at the mobo and noticed that he might have some bad caps. I've attached pics for you guys to look at. Are those bad?
Nothing was changed software or driver wise, so I really don't think it's software, driver, or OS related. It seems hardware related.
Also, do caps on a mobo all of a sudden go bad or is it gradual? Since there seem to be so many potential bad caps (judging by all of the caps that have a brown solution that came out of them that is sitting on top of them), I don't know whether that happened all of a sudden or over time. I did read that bad caps do cause a system to not boot up fully.
Please advise ASAP. Thanks.
The pictures aren't showing up.
Caps on a mobo can go bad either gradually or all of sudden. From the description you have provided, it does sound like there are bad caps. But it would be easier to diagnose if we can see the pictures.
yah, no code for any pics either... use an image hosting site, like imageshack or something.
