Bad Axe 2 memory problem
slmcgra
Ok, here's the situation: I have four sticks of memory, a pair of Geil 1GB sticks (GX22GB6400UDC), and a pair of Geil 512MB sticks(GX21GB6400UDC). Both the same type of memory, DDR2 800.
With two sticks installed (2GB), the computer is perfectly stable (both sticks in the blue slots). If I add the additional two 512MB sticks (blue or black), the computer becomes unstable. Unstable meaning: it will fail with aggressive memory settings, fails orthos early.
If I do a memory test (memtest86+ v1.65) with all sticks in, I pass with no errors (6-8 passes). The one thing I have not tried yet is install ONLY the 512mb sticks, but I will try this later today.
My question is: Is there any reason I am not able to run 4 sticks of memory? When I first set the system up, it seemed reasonably stable with the 4 sticks. It seems to have deteriorated since (2+ weeks) and is now very unstable with these 4 sticks. 2 sticks is no problem whatsoever.
My current thinking is to RMA the 512mb sticks and just be happy with 2GB. Any insight into this problem is appreciated.
system config:
E6600 @ 3.4GHz (378FSB)
BIOS 2333
1.425vcore in BIOS (1.4v at load)
stock mch/fsb volts
runs 60-64C under orthos load
533/266 frequencies
4-4-4-12 @ 2.2v RAM settings
C1E enabled (also tried disabled)
EIST disabled
With 2GB RAM installed, 22hr 55min orthos large stable with above config. With the extra 1GB, the system would fail under 1hr typically.
Exactly which tests are you using in orthos that are causing the fails? Depending on which tests fail may help point to the problem. I don't know the specs on that ram but if they are made with different IC's then overclocking can be a crap shoot at best when you mix them. The memory controller may not like the different sticks, or one of the sticks may be bad. Memtest86 usually catches most problems but it's not the end all be all of ram problems. The windows memtest is good to run also. http://hcidesign.com/memtest/
orthos fails on large. I think this is just a problem with the combination of hardware and overclocking. I have RMA'd the ram - Newegg was very good about taking care of the situation. I just had to give them a phone call and they took care of the restocking fee.
I had upped the northbridge voltage, and I think it actually crashed sooner when I did this.
Anyway, thanks for the assistance. I will be living with 2GB, since I think it is worth it if I can run 3.4GHz daily!
