Backup Software for RAID
pickxx
Everyone lately seems to want to RAID-0 drives, which i have never done before, and i wanted to give it a go. however i need two pieces of advice......
I am going to RAID-0 two Raptor X drives with my onboard chipset (680i) and i wanted to use one of my 300GB drives to back it up. What software should i look into that would allow my single 300GB drive to automatically backup my 300GB RAID-0 array nightly or at a predetermined amount of time? I figure if i loose one of the two Raptors i am not totally screwed with what data i have on them.
2ndly is i have heard there is imaging software where i can set up my computer the way i want. Load windows, my programs, and the like and i can make snapshot (for a lack of better word) of this config and then if/when i want to restore my computer i can use this snapshot to load everything......so i don't have to spend 24-48 hours loading and configuring all my programs all over again.
Any help would be great,
Thanks
2ndly: Bootit next generation $35 or so, I use it on a IDE drive.
in the dual-boot menu, there is a
"maintenance"
which can go to the icon
"image sets"
where you can backup multiple partitions with the "start" choice.
and even set an audible alarm for when it finishes.
only catch is checking whether it all works with your hardware, os, the
choices/options setting it up, etc
latest ver 1.82
at least once it has saved me from a reinstall of an OS
