- Feb 11, 2013
Hi all people, after couple of Issues with idle temps my new 3770k i've decided to make some test and ask all of you for thoughts about this chip quality..
I had already a 3770k some time ago, the worse silicon lottery I had in my life with a intel processor, that required some high 1.20V to reach 4.2GHZ.. and at very high temperature, this new one with my first impression are of a good god damn chip, to the moment i am using negative offset voltage to lower the high amount of voltage supplied by auto-voltage.. to the moment it seems rock solid with a -0.060 offset that under load sit at 1.072V to keep running 4.2GHZ at some average 62C under Prime95 with peaks of 67C on 2 cores. (which I think its kinda decent for my 27.6C room temp at the moment of the test with just an h100i with balanced mode) I think im still can keep increasing the negative offset and lower the load voltage but i do not wan't to make the idle voltage so low, so i think i will keep testing tomorrow and see how low can this chip still be stable, i made some gaming sessions on BF3, AC3, The witcher 2, Crysis3, Dragon Age Origins, Batman Arkham City, Far Cry 3 and hitman: absolution. then a P95 run for about 25min still rock solid, no crash no errors.
share your thoughts
. im pretty happy with this chip ATM, if i can keep this kind of lower voltage i will start to push it hoping some 4.6-4.8GHZ with good voltage + good temps.
share your thoughts
