AV Command Center
AshleyG
This system is going to be serving video (mostly powerpoint; potential for video clips down the line) to the main sanctuary projector and simultaneously recording a combined audio stream (single output from sound board) for storage and post-service editing.
$1100 max, inclusive of tax and shipping
Knoxville, TN
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
CPU, MB, RAM, SSD (OS/software), HDD (media storage), PSU
Case: CM ATCS
Video card: EVGA GTX 560 Ti
6) Will you be overclocking?
No
22" 1920x1080 for the desk, 800x600 projector (possible projector upgrade coming next year)
Plan on buying within the next 48 hours, build complete by the weekend.
9) What features do you need in a motherboard?
Lots of SATA ports, RAID 1 support for the storage drives, fairly long shelf life (shooting for 4-ish years of upgradability if possible)
Yes, Windows 8 Pro x64
What software and hardware will you be using to record the audio?
I was planning on using Audacity for the recording and editing. I'm really not sure if I'd need a dedicated sound card, or which one I'd need; would onboard audio suffice (line in), or should I look into another solution?
I think you would need a solid sound card for this. However, I'm not 100% sure what the best audio-recording setup for your particular usage and budget would be. I recommend hitting up the Computer Audio subforum for advice on recording software and hardware.
For now, I'm going to set aside $150 for the audio recording aspect. So that leaves $950 for the PC. Which is more than enough considering streaming video isn't all that intensive and recording audio is not as heavy duty as it may be.
$307 - Intel Core i7-4770 CPU
$77 - ASRock H87M Pro4 Intel B87 mATX Motherboard
$120 - G.Skill Value Series F3-12800CL10D-16GBXL 2 x 8GB DDR3 1600 RAM
$171 - Samsung 840 Series 250GB SSD
$180 - 2 x Seagate Barracuda ST2000DM001 2TB 7200RPM SATA 6.0Gb/s Hard Drive
$80 - Seasonic G Series SSR-550RM 550W Modular PSU
Total: $935 shipped
