audio lead problem... can anyone help me out?
KanadaRob
i bought a tv tuner card for my computer because i am able to get cable in my dorm room here. i'm using a "mini" case which means everything is really compact, i just had enough room to fit the tv tuner card.
so, the problem is that it comes with an audio lead cable from the tv tuner card to the motherboard. the audio lead cable is that really small cable that you usually use to plug the cd rom drive into the motherboard/sound card.
it looks like i only have one audio lead cable slot on my motherboard (the soundcard is built in to the motherboard), is there anything i can do? is there such thing as a splitter for audio lead cables or is there some kind of converter i can buy and put on the end of it? is there any other sort of alternative?
i've noticed that on hard drives, there seems to be a slot that fits this type of cable but there isn't any cable plugged into the hard drive i'm looking at. why do hard drives have this same kind of cable slot? is it at all possible i could plug it into there?
thanks for any help or comments.
You'll be ok unplugging the cdrom cable from the motherboard - it's rarely used any more, most programs get any cd audio in digital format off the disk, or just convert it straight to mp3.
actually, that's not so bad of an idea. i mostly use my two drives for copying purposes and when i do want to listen to a CD, i usually go to mp3 and put it on my hard drive.
however, it's not just CD rom drives i have, i basically have one cd/dvd burner and another cd/dvd reader. so, if i disconnect the cable from the motherboard, does that mean i won't be able to get the audio when i play DVDs? do DVDs do things digitally or do they go through that audio cable to the motherboard?
i hardly watch DVDs on my comp, i mostly use those DVD drives for copying purposes, i can't even remember the last time i watched a DVD on the computer so perhaps i could just leave the wire in there and if there ever was a time i needed to watch a dvd, i could swap. but let me know about how DVD drives work in terms of sound. thanks.
pretty sure its the same answer, those plugs hearken back to days of 12mhz 286's, all the DVD sound processing takes place on your motherboard via the IDE/SATA/SCSI or whatever cable. Your DVD's will play just fine without that audio cable connected (mine do)
Hard drives do not have an audio cable connections. Your probably mistaking the MASTER/SLAVE/CABLE selection pins for that
The only thing those cables are used for these days is playing CD's in analog mode. I don't even have mine connected. Even if you did want to listen to a CD on your computer, programs like windows media player play the CD's digitally, so they will still play even if you remove that cable.
