malicious said:need a straight atx psu right?
tryin to get a new psu for my socket a system but future proof it for a 939 sli build
E4g1e said:You will need a PSU that has relatively high amperage ratings for both the +5V and the +12V rails if you're going to use the same PSU for both your current and your new setups. Unfortunately, that means buying a PSU with far greater wattage than what you'd normally need for either rig.
malicious said:yea .. my buget is a little light too
think i might just stay with a single card setup for my next rig
newegg has a thermaltake TR2 430 20+4 w/ pci-e for 29.99
everybody raves about it
i think it's the one.
E4g1e said:Actually, that PSU is way overrated by the 'Egg reviewers. The truth is, its build quality is really crappy to begin with. And it has a +12V capacity of only 18A on its single +12V rail - nowhere near enough for a newer A64 system, even with a single high-end graphics card. (Heck, that PSU could have been a rebadged Deer or Powmax unit, for all I know.)
The truth is, to get a PSU which can handle an A64 rig with even a single high-end graphics card requires spending at least $70.
malicious said:what are your recommendations
E4g1e said:If your budget is about $50, you can't go wrong with any of the FSP Group 400W or higher units for a high-end A64 with a single high-end graphics card. Above the $50 range, Antec distributes good units - but choose carefully.
malicious said:why do you like fortron
E4g1e said:It's just that they're the only known "good" brand in the sub-$50 range. Most of the other sub-$50 PSUs are likely rebadged versions of the brands in the first post of the PSU's to Avoid for High Performance or OC'ed Systems thread.
malicious said:yea the fortrons are KNOWN to be good
how about this one
http://www.newegg.com/Product/Product.asp?Item=N82E16817709004
modular is nice me thinks
sn_85 said:about the only choice under that price range is the sunbeam. i'd check out the enermax liberty 500w which is about 120.
malicious said:
