Newbie here. Please have patience..
I have several external USB drives (Seagate, Verbatim, etc.). All are 12 volt with varying amperage.
I also have just as many AC adapters for same.
Is it possible to use an ATX power supply to power just these USB drives?
The drives are connected to my PC via a 7 port powered Startech USB 3.0 hub with power coming from the PC's power supply.
Can the molex plugs on the ATX be adapted to the 5.5x2.1mm plugs on the external drives?
I would like to have the only connection to the PC to be the USB cable, and possibly a common ground, if necessary.
Any help or WARNINGS woud be appreciated.
ShaynaLu
ShaynaLu
