- Jun 27, 2001
well i dont tell them its for F H the breakers trip and i go *shrug* told you that room wouldent take 30 computers rolleyes
p[H]ant0m said:I figured as much. It's just nice to know that there are some places out there that are willing to maintain a working setup. My job for instance, we are stuck within the constraints of what we have. Something blows or a breaker pops, you move it to a different circuit and hope that it doesn't happen again. Yay for gov't bureaucracy...![]()
SmokeRngs said:Many of us recently upgraded from PIII 700's to P4 2.8 Ghz Preshotts. On my part of the floor, we got probably a couple of hundred of these things. Ever since, breakers were being tripped daily. I got lucky and the circuit I'm on wasn't overloaded. Yesterday they had an electrician in here running new lines and doing some other stuff. Hopefully this will take care of the problem in my area. At least the flooring was designed in a way so they only had to pull up some carpet pieces and metal floor pieces so it was easy to run new lines. Other than that, the building sucks and should be torn down and rebuilt. It has to be one of the worst designed buildings I've ever been in and inefficient as hell.
Oh yeah, yay for state govt.
Hito Bahadur said:Tell them to buy AMD's. They would have less heat and power problems.![]()
I can relate to that.p[H]ant0m said:Oh if it were only that easy!I've been trying to convince my boss to order a few Opteron workstations now that IBM is selling them in their Z Pro line. He just dismisses the thought, as he is firmly entrenched in the "AMD is budget equipment" mindset. No amount of benches, documentation or testimonials will sway him. I guess we are just Intel-centric no matter how much it sucks.
