Im looking for an attic switch recommendation .... And yes attic mount is pretty much a requirement.
Basically in my garage area I have 2 cameras , looking to mount an AP, and in the future add a 3rd camera. All powered via PoE. In addition to this I have a TV mounted there (Mainly because I can .... and a garage TV is pretty bad ass).... But with that I have the need for another one or two ethernet drops.
So instead of looking to run 4+ runs from the main switch to these devices I'm hoping to run one and just put it to a switch. None of the devices will come anywhere near maxing a single line.
Currently I got my hands on a GS105PE for free from my dad, and am having issues (Netgear GS105PE), however this is far from a perm solution since I need another two PoE connections....The current thought is to put a PoE Switch (Even if partial) that can handle 4 devices (Which is the max PoE needed in my use here) in the attic. To offset the extra heat I've been thinking why not pick up a used 24 port, or 48 port (maybe 16?) Gigabit PoE switch that is actively cooled and use that with disabling of all un-used ports to alleviate heat. Being a garage I really couldn't care less about the noise created (it is ~2 insulated walls and 20 ft away from any living space).
Anyone have alternative suggestions, or switch suggestions?
Should probably note: I am located in Orlando FL, so it gets fucking hot up there, well outside of normal operating temperatures. The switch would be under pretty much no load outside of 2 or 3 continuous 10/100 connections.
