- Aug 29, 2025
View: https://www.youtube.com/watch?v=pRN2gw0arw8
Smh, right after I bit the bullet on some cheapo chinese knockoff from Temu this happens. Always was uneasy thinking about it but I saw LTT Labs review some chinese knock off mice and they performed well, so I decided to finally get one just to see if lightweight mice are worth the hype or not. Should have trusted my gut.
Hoping the return process won't be a headache. There have been some mini-PC manufacturers in the past that also shipped with malware in the recovery partition.
TL;DW
Attack Shark G3 Pro mouse software was compromised. Not to the point where you need to reinstall windows if you downloaded and used it, but it was infected. The command & control servers are already dead on the software so should be fine but still. Very sus
