Attaching a radiator with velcro?
2wiced
How well would that work? I was thinking of attaching a 200mm radiator to the 650d in the front. This way it would not have to be drilled
Do you mean a 240 (2x120)? Or a 2x100mm? Or a 200mm square?
One thing I would be concerned about is weight. Filled thats going to be about 1.4kg (about 3lb) hanging off some velcro. Unless you strap it on, but then youll probably have to cut holes for straps/attachments.
How were you thinking of attaching it?
Although there are super strenght velcro out there, my concern would be the glue holding the velcro straps to the metal would loose it's adhesiveness over time due to the heat generated inside your pc
If you are that desperate to have a large radiator hanging outside, but still attached, to your case, how about some good old fashioned Bondo?
Bondo, really? Lol
Industrial grade 3M velcro would probably work. But why not just drill 4 little holes you won't even see? And as long as you already have the tools, it's free!
Dude have I got an idea for you:
Adhere anything to anything with that stuff. :D
