This was taken from my friends german magazine of ati r600 and just translated it for me, idk if its worth it
Price: $449.99
1. Unified shader architecture.
2. 64 pixel/vertex shaders. Since ATI is incorporating an Unified shader architecture, these 64 shaders can be either all pixel, all vertex or a combination of both. In contrast, the R580 based X1900XTX had 48 pixel shaders.
3. 80/65nm fabrication process, though ATI wouldnt elaborate on the exact split as well as why they werent sticking to just a single fabrication process.
4. There was also some passing mention of GDDR4. However, we could not confirm either way whether the R600 would come with GDDR4 onboard. Later variants of the architecture will definitely the updated DRAM standard.
5. As for the clock speed, ATI said they werent really too concerned about raising the clock speed to particularly high levels, so we suspect the core clock may not be much higher than the current X1900s.
6. It will obviously be Vista ready and (ATI claims) has been built from the ground up to support DX10.
7. The R600 will also be the first practical implementation of ATIs GPU concept. This is something we would be very interested in seeing because if this works as well as ATI claims, then apart from cutting down CPU load, it might put certain PhysX processor manufacturers out of business, simply because ATI cards would not need an additional card to do necessary computations for Physics. The onboard GPU will take care of it.
8. The launch of the R600 is expected to be somewhere around october 2006
Price: $449.99
