ATI HDMI Out question
wolf2009
Monitor - ASUS MK241H http://www.newegg.com/Product/Product.aspx?Item=N82E16824236033
Video Card - HD 4870
Drivers - Catalyst 9.10
HDMI cable - some cheap $3 cable off amazon
ATI DVI to HDMI adapter supplied with the card
So i just configured my monitor for the first time on HDMI input.
For some reason, the text on webpages seems a little more sharp and aliased. on DVI it seemed more smoother.
Don't know what's wrong or it's supposed to be that way.
This link:
the link you have is broken.
Use the DVI input? They are electrically the same (HDMI/DVI), and thus, you see the adaptor. The DVI output, however, also may have several analoug backup pins, to allow older VGA connections to work.
I haven't had any text clarity issues, so far, on a HP 24" monitor, via HDMI. (converted from DVI).
It's probably the cheap cable. :eek:
