I recently jumped on the ATI bandwagon after being with Nvidia for the past 5 yrs. I purchased both a 4870 and a 4850 for an upcoming upgrade to 2 pc's.
The "problem" that I discovered is that these Ati HD cards have an audio chip that sends its signal out through a HDMI signal. If you don't want the use this signal because you want to onboard mobo audio or a separate audio card then you have to disable the audio. I tried to uninstall the HD audio, but it reinstalls itself on reboot. I guess having a red "x" through the HD audio in my device manager isn't a big deal though. I discovered this while building a cheap pc for a family friend when I used an HD 3450 card. I couldn't get the mobos onboard audio to work till I decided to take out the video card and try the onboard video. After that I "discovered" the card HD audio and disabled it.
My questions are:
(1) Are these cards geared towards the home theater crowd?
If you use the HDMI with an LCD monitor, its seems that you'd have to use a monitor with speakers since the HDMI cable also carries audio.
(2) For those using these cards for regular pc/gaming, is there a way to remove the HD audio from the device manager without it popping back up on reboot. The Powercolor HD 3450 card I used came with piss poor documentation and their website sucks too.
Thanks for your help and input. Next time I do a little more research before I buy
My questions are:
