alg7_munif
- Oct 9, 2006
I have always had problems with the ATI drivers causing issues with certain monitors. That is a long and drawn out story, but basically after installing the ATI drivers, from the Radeon X800XT-PE to the Radeon 4870X2, the system won't output any video signal over DVI to certain monitors. One monitor is my Viewsonic VP201s which is an old monitor at this point, but you get the idea. I've seen this even with more modern displays, but I've never had the problem with my Dell 3007WFP though.
As for game issues, I had issues with the 4870 X2 in Crysis on multiple systems. So it wasn't just isolated to my Skulltrail setup. The best ATI cards for me were the X1950XTX and the X1950Pro. I had those in a couple of different systems and even with Crossfire enabled on both of them, everything always worked very well for me. So I'm not saying I've always had problems with ATI drivers in all scenarios. Not at all. However there are certain irritating problems that I've never seen a resolution to such as the DVI issues. Then again, I've heard NVIDIA cards have that problem in some cases too. I've never seen it though.
I won't normally hesitate to put ATI cards in my systems provided that they are providing the best performance possible for my money. The last time that was the case was when the 4870 X2's came out and I ended up returning one and selling the other one off because I couldn't make them work.
The monitor issue might be an issue for you but I also had a problem with the way nVidia driver handles the EDID info especially when I disconnect my monitor and connect it back again. I never had this issue with my ATI driver. This is the main reason why I switched from nVidia to ATI. I need to disconnect and reconnect my monitor often because my PC is sharing the same monitor with my PS3.
What kind of problem did you encounter with your X2 and Crysis? Is it a performance issue or something trivial such as crashing? If it was just a performance issue, God knows how many performance issues that I encountered when I had my 7950GTs and 6800 Ultras in SLI but I won't make a general statement saying that ATI driver is better than nVidia driver just because I had some problems with the nVidia driver. To be fair, I also had a fair amount of BSODs caused by nv4disp.dll but I still don't think that a driver from a company is better than the other.
Btw what other issue did you have with your ATI driver other than what you have mentioned before? What other ATI cards did you use before this? Did you use any HD 3800 card? Your X1950 cards didn't give you any problem right?
