Cablespider
- Jan 21, 2006
I was hoping this would fix the random gray screen lockups I have been experiencing with the 5750 in my son's Win 7 (64-bit) computer. From the release notes, it doesn't look like they've fixed it, but I did notice a new win 7 known issue that may be what is causing my problem...
"On some system configurations changing desktop resolution may causes the OS to stop responding when real-time protection is enabled in Microsoft Security Essentials."
Crossing my finger this is the issue.
btw the texture bug is still there in borderlands...
fixed in the 9.12 beta's though
Disable Cat AI
I think thats why it works in 9.12 beta tbh.
Looks like they fixed the LOD when using SSAA modes...
Does this mean when SSAA is on stuff won't be super blurry anymore?
Issues with large mouse pointer NOT fixed...![]()
I cant install the damn thing on my Windows 7 X64
When I click the Install option, it says that Catalyst Install component has stopped responding
Any ideas of the cause?
Yep, the install component is compiled with VS2005, and there is a fix for that http://support.microsoft.com/kb/961894
