ati 9600 pro with nvidia sound driver issues???
jbligh1
OK, so we built my friend a computer about 4 months ago--no problems. He's got an asus a7n8x delux mobo and a 9600 pro. For the last four months, we havn't had a single problem with it, we even oc'ed it a bit w/o a hitch. Recently, my friend tried to install a dvd+- rw drive and a card reader/floppy drive. This is when the stuff hits the fan: upon start up, windows fails to boot every time. This is what we have done to try and fix it:
1) Removing the new drives and restoring the system to its previous physical state. We figure that it all started not working when we installed the drives, so removing them might just do the trick. Nope . . . . we thought wrong; windows still fails to boot entirely.
2) Repairing windows. yeah, this is supposed to fix everything, but it doesnt. We got it to boot from the cd, and install the setup files, and run setup, but after setup completes, windows fails to boot entirely. And now we cant even get into safe mode anymore.
3) Reinstall windows. So we backed up his info by taking the hdd out and installing it in another system. After putting the hdd back into his system, we boot of the partition commander disk and format the drive. We then boot off the xp disk, install windows, and everything works fine . . . until we try to install drivers. (BTW, we installed the new dvdrw drive and the floppy and they worked fine, so we discounted their influence on the problem). The first driver we install comes off the mobo disk for the nVidia sound drivers and utilities. They install w/o problem. Reboot, then video driver install, they install w/o a problem, until we have to reboot. Windows fails to fully load. Back to our original problem . . . so, now we have an idea that it is either a hardware or software issue with the graphics card. In my system, i have an aiw 9700, so we put his 9600 in mine, and it worked w/o a problem, so it probably isnt a hardware issue. Next, we put my 9700 in his computer, works w/o problem. This leaves us with an important question: wtf? So, we swap the cards again, putting the 9600 back into his system. Everything works, except, for some reason, the sound drivers are gone! We done know how they got unistalled, but in the device manager, they came up w/o a driver. So, we install the sound drivers, reboot and windows fails to fully load.
We repeated (nearly) everything above with the newest sound drivers as well.
We've come to the conclusion that we can't have both the audio and video drivers installed simultaneously and have windows load, which is fubar.
OK, I think that's all we did, and we don't know what to do anymore. If you all have heard of anything like this before or know how to fix it, you're help is greatly appreciated. Thanks for taking the time to read all this . . . . .
Similar incidents with me have proven to be RAM or CPU related, or possibly mobo.
1. Get memtest86 and run it for a few hours.
2. Install with the bare minimum and run Prime95 and/or another cpu burn-in program.
if it passes both of those, it's probably the mobo.
I had a similar problem as well . . . I installed new Catalyst drivers and XP Pro got caught at the boot screen. However, I just reinstalled XP and it worked fine . . . sigh.
Ok, i ran memtest overnight for i suppose ~8 hours, no problems, i ran the cpu arithmatic and multimedia tests in 30x sequences for a few hours, nothing wrong. Although i did notice that the -12v supply is constantly at -12.6 and change, could this over time cause this issue?? Also, he has had problems with power fluctuations to his cpu hsf in the past. If he gets a new psu, it would cure the fluctuations, but would it solve the other problem, or is that permanent damage?? thx.
try uninstalling ALL the video and Sound drivers and reinstalling them, might work
New PSU might do it. Give it a try, can't hurt.
I've tried uninstalling all the drivers, sound and video, and no matter what i do, short of formatting (again) there must be some residual data left after the uninstall that still messes it up, maybe some where in the registry, i dont know . . . i've got to find a good mobo tester, is there a way to run some sort of test on the audio and agp slot on the mobo like i did the memory? I suppose that would tell me if the mobo was kaput.
thanks, y'all
we gave up trying to figure out what was wrong with it when we put in another graphics card in his computer and it worked fine with sound. we just rma'ed it, go figure?
It sounds like one of two things.
I believe it is just a driver conflict. The drivers you are using off the motherboard CD are probably very old. I have the newest nForce drivers on my A7N8x-DLX and haven't had a problem with them. The install order may have messed something up and/or some type of Windows update possibly.
You had mentioned that the PSU may not be up to the task. I would have swapped out PSUs with your system to test that out. Adding hardware will always put more stress on the system. Although the hardware added doesn't use much in the way of power consumption; it may have been just enough to push the PSU over.
There is a chance that the problem could be both of the above.
