- Apr 16, 2004
What does DEP stand for ?Mutalys said:Unfortunately from what I've read
Microsoft + Software = Problems.
Really, there are more problems with SP2 than just A64, but the reason why they are suggesting that people with A64 skip SP2 is because they didn't properly work the DEP. You can disable this I believe and have no problems.
qftOldPueblo said:The short answer: Its Sigma's fault, its a legacy product per Sigma, releasing a fix is up to them, you can turn off DEP via the boot.ini switch /noexecute (remove it) if you really want SP2 AND the Sigma product right now.
Mutalys said:Man, I haven't played Gunbound in ages. My old clan got me addicted to that. Sucks that you can't play. Have you tried reinstalling the game? Whats the blue screen say?
Galvin said:I wonder if there is more problems with people upgrading SP1 to SP2 instead of fresh intalling XP then installing SP2.
Upgrading MS os's usually causes problems vs fresh install.
LOL it's not AMD's or MS's fault. Sigma Designs has a buggy driver for the Hollywood Plus decoder card. See my link above, the rebooting problem pre-dates SP2/DEP.Rizen said:This sucks. It's likely going to put the A64 in a negative light, even though it's MS' fault. Great.
