Athlon XP Stepping
KINgGh0sT
AMD Athlon XP
AXDA25000DKV4D 2314247200561
AQXEA0331RPMW
That is my stepping is that good?
mine is roughly the same (0330) and i can get up to 2.4, but i need a crapload of volts(for air at least) to get to to(1.875 i think)
That's a good stepping, it's unlocked, and many AQXEA Bartons do well in the OC department.
Since your PM box is full, how did you manage to get the Zalman to fit on the NF7 Board?
I guess I suck at putting artic silver on or I wrecked the clip for my Volcano because it used to load at 45ish, and now it loads at 49ish
