- May 18, 1997
Umm no. Intel still rules in market share, total sales, etc - far more important than winning benchmarks by a few percentage points.Obi_Kwiet said:Well, the last place Intel ruled in has been taken over by AMD. pwnt.
no it's not. if you look at the diagram just before that picture of the core, it clearly shows that the cores would communicate via the SRI, not HT linkNotice that you are seeing two identical K8 cores that are basically connected through a HyperTransport bus.
i agree with this, but there's one slight problem in the logic. bench junkies do one thing at a time: bench.If you are a hardcore gamer looking at moving to dual core computing, you would likely be foolish to consider anything else but the AMD Athlon 64 X2 processing platform. Our single threaded gaming benchmarks clearly show that the Athlon 64 X2 is a better performer in the gaming arena. If you are a benchmark junkie, the X2 is the obvious choice.
EnderW said:far more important than winning benchmarks by a few percentage points.
Maybe you missed the part where the entry level Intel DC chip costs less then half its AMD counterpart.Jaxor said:Umm no, not when it comes to more bang for your buck. I'd rather have a better CPU at a better price than a slower CPU at a higher price.
James54321 said:I only hope that once the actual products start hitting the market, that prices will go down to something a bit more reasonable. Thanks [H], great preview!![]()
- James
James54321 said:...So it was that I was left with little options. I could purchase an A64 and get great gaming performance, but forget running two MMO's in tandem, much less constantly (and smoothly) switching tasks between MMO's and databases. Forget editing sound/video and running graphics-intensive filters within a reasonable amount of time and with little frustration...
- James
I like how you think(cf)Eclipse said:Kyle, have you guys taken the time to try your hand in OC'ing, or did AMD give a thumbs down on that?
Exactly. I could use the XP-120 I already have.(cf)Eclipse said:and with the power draw figures given by anandtech, it doesn't look like heat will be a significant problem![]()
Max Icc (processor current): 80A
EnderW said:Looks good - except for the price. Do you know when they will be available to purchase?
no. 110w outputNumbLock said:Is this a typo?
I noticed this while committing this article to memory!
Are there any disadvantages? Are there games and benchies that actually run slower than their single core counterpart at the same clock freq?
Sheff said:I'm giving this processor some serious thought, but I'm concerned most about memory capacity. What is the max amount of memory you can pair with this processor? If I'm getting the MSI Platinum, is the max amount 4 gig or will the bios flash allow 8 gigs (2 gigs per slot)?
If I want this ammount of memory, will I have to move up to a workstation board/opteron solution?
James54321 said:I took the Northwood plunge from a great PIII O/C and an AMD AthlonXP 1600+ and I never looked back to an AMD CPU. This didn't mean that I didn't like AMD CPU's,especially at their price/value point, but like Kyle, I was simply floored by HyperThreading. At first I thought it yet another Intel marketing gimmick.
However, after building solid AMD-based mid-range systems for clients and friends, I find myself going back to my trusty Northwood every time. Sure, the AMD CPU's smack my own in gaming, but the fact that while running a CPU-intensive app or game while trying to do something as easy as web page / database administration and experincing very noticible (and annoying slow-down) on AMD systems, I just can't justify currently "upgrading" to an AMD system.
Or I could go with Prescott... ugh, such a downgrade from the great Northwood core and I would have to invest money in a motherboard that was actually slower than my 875P? BAH!
So this article comes as saver for me. I'm looking at the 4400+ with a lot of interest and while I won't pay the near $600, I'm hoping my Northwood system can hold for just long enough for prices to come down to something a bit more reasonable. I'm psyched! Not only can I have gaming performance, multitasking performance and effecient thermal technologies features within one CPU, but I can also "upgrade" using one of the current S939 motherboards/technology?
What is not to like?!?! Thank you AMD! I only hope that once the actual products start hitting the market, that prices will go down to something a bit more reasonable. Thanks [H], great preview!![]()
- James
i have a feeling it'll be a mix of the two, as turion doesn't need to do quite as high speeds as X2, and the 1.35v model = 35w, that's a 70w dual core. amd seems to have spec'ed these for 110w, which would imply it's very closely related to the normal desktop coresserbiaNem said:Are these processors more closely related to the Venice or Turion? With power consumption being so low, it wouldn't surprise me if the dual-core was two Turions.
EnderW said:Umm no. Intel still rules in market share, total sales, etc - far more important than winning benchmarks by a few percentage points.
The cheapest X2 is $500, compared to $240 for the entry level Pentium D 2.8GHz. Intel definitely has a big advantage here.
NEVERLIFT said:I think a cheap intel system with that 820 is not so cheap add the high priced DDR2 and expensive DC mobos.
I think it will be the same price... around $800 for 4200 + 939 board + 1gig DDR.. As an 820 setup. Nevermind the AMD setup will beat 820 like a red headed step child.
There are s939 mobo's for less than $100 that are very good, take the CHAINTECH VNF4/Ultra Socket 939 NVIDIA nForce4 Ultra which is $92 and comes with a $10 rebate and Corsair has their 1gig for $79 and you see that price is $700.Dew said:Your f@nboyism is annoying.
If you call a 26% price difference around $800, then yes.
P4D 840 - $240
ASUS Mobo - $200
Geil DDR2 667 1GB- $150
Total - $590
AMD64X2 - $540
ASUS Mobo - $140
Giel DDR 400 1GB- $85
Total - $765
My beef with the X2 is the steep entry point. Even with higher cost ram and motherboards, Intel has a better entry point. You pay more for the "same" performance with intel, but it costs a less to get in the game.
